Results 1 to 11 of 11
Thread: Hayward AquaRite SWCG
    May 2012
    Houma, LA
    104
    When installing the panel, wouldn't you want power to it all the time. The flow switch would be what controls the chlorinator to produce chlorine. Right?
    If this is the case then the pump would be he only item that needs to be on a timer. AquaRite panel would be hardwired.
    Or does the panel and the pump need to be on the same timer. This would cause the panel, along with the pump, to be completely tripped on/off. Would this not cause the settings and whatnot, in the AquaRite panel, to be lost?
    If both the AquaRite panel and pump need to be on said timer, what timer would be sufficient?
    Sharkline 18'X40' Matrix 54 AGP(21k gallons), Pentair Sand Dollar Filter System with 1-1/2HP Dynamo, 125 lbs of ZeoBest., Hayward AquaRite SWCG w/T-Cell 15 TurboCell, Confer Plastics STEP-1 Easy Access Above-Ground Pool Steps, TF-100 Test Kit
    38,295
    Re: Hayward AquaRite SWCG
    Read the manual. It stresses that the power should be switched with the pump to prevent generation with the pump off. The flow switch is a backup.
    What timer do you have? Any Intermatic would be fine.
    May 2012
    Houma, LA
    104
    I figured the flow switch is just a backup.
    Right now all I have is the Intermatic P1131. Somewhat like this.
    All I was powering before was just the pump. Now I need a timer that'll allow 2 items to be on said timer.
    38,295
    The AquaRite must be hardwired anyway. You can hardwire your pump as well to the same timer. An Intermatic T101 I think is all you need.
    May 2012
    Houma, LA
    104
    According to what I am reading/seeing in the maual, all I need is a single pole/single throw timer.
    Now the question is, is it OK/correct to tie the pump wire and the AquaRite panel wires together and put them on the bus bar of the timer? I figured, my pump and the Aquarite will only be 18 amps.
    38,295
    That is the way it's usually done.
    May 2012
    Houma, LA
    104
    I didn't think that would be the correct way and I'd have to put each equipment on it's own set of buses. I guess that's where I was messing up. I was looking for a timer that would have enough connections to carry each on it's own. Like the GE15135 timer.
    38,295
    My previous house just have the wires to the pump and the wires to the Aquarite on the same screw terminals in the T104 (230V setup).
    Jun 2013
    Philadelphia, PA
    143
    Not to hijack this thread - but I'm curious - what if you don't have a timer in your panel? My timer is on my pump (Built-in to the Intelliflo variable speed.)
    Leisure Pools Riv 30, 8500 gal, IG fiberglass, 200 sqft cart filter (Clean & Clear 200), Intelliflo 3HP variable speed pump, Aqua Rite SWG, auto cover, installed 5/2013
    Aquacal Superquiet 110, installed 6/2014
    TFT 100
    38,295
    Quote Originally Posted by TroubleFreePat
    There are a couple threads discussing the use of a current sensing relay to prevent the SWG from getting power when the pump is not running.
    May 2012
    Houma, LA
    104
    Well, got everything hooked up. Powered it up and wala. It all works. I hate messing with electricity. Not that I can't do it, just had a couple bad experiences as a kid with electricity.
    Now just need to find out why the filter head is leaking. Must not be tightened enough. Might need to get a new oring.
    Anyway, comments on my pump pad setup.
