Results 1 to 8 of 8
Thread: My problem seems to be high TA
    My problem seems to be high TA ( can't even measure it because I get false readings) cya at 90 and ph 7.0 last year we had to keep fc above 7 to kill algae it's a 60000 gal pool so draining and refilling is expensive. from what I am reading I'm not sure why the ph is low and the ta so high.
    22,553
    Re: My problem seems to be high TA
    What kit are you using to test with?
    You're CYA is way too high. You're going to have to drain some water to get it back reasonable.
    Tell us more about the pool and equipment and how you normally chlorinate?
    In ground pool approx 25/50/12 60,000 gals. pureflo sand filter richardson circ pump polaris pool cleaner, normaly chlorinate with tablets in the skimmers. test kit K-2006 Taylor
    38,521
    Welcome to TFP!!!
    What is happening when you test the TA? With continued use of tablets, I would be surprised that the TA is high. Are you sure it is not very low?
    What are the test results for your tap/fill water?
    22,553
    You have a good test kit. Now you need to spend some time in Pool School reading the ABC's. Tablets in the skimmer is a bad thing. They create an area of very high FC and very low pH whenever the pump is off.
    What problem are you having with the water? What does it look like?
    When you say you get false readings on the TA, exactly what is happening?
    let me test the fill water and see. thanks just tested my fill water 100ppm ta I know tablets in the skimmer is a bad thing but my hayward chlorine feeder is not working right yet. We leave the pump on 24/7 during swimming season. Right now the water looks good at 74 degrees as it did last year but with warmer temps comes algae. We have had to keep the fc above 7 to keep the algae out.
    38,521
    According to this chart: pool-school/chlorine_cya_chart_shock
    7ppm is the absolute minimum FC that we recommend for a CYA that high.
    Have you read all of Pool School yet? Tablets are just not a good long term solution ... especially if you do not want to have to replace water every year.
    Jun 2012
    Howell, NJ
    977
    What is happening on the TA test? What kind of false reading do you get? Either way, like others have said, you should consider switching to bleach and replacing some water to get the CYA down.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
