Results 1 to 9 of 9
Thread: Mounting a Separate Pump and Filter
    May 2008
    rock springs, wi
    45
    I will be purchasing a separate pump and filter, not a combo kit, so there will not be an integrated mounting base. How do I mount the pump and filter? I am assuming that there are bolt flanges on each piece and that they can just be bolted down to the pad, but pictures are unclear.
    Do I have to have a poured concrete pad? Why can I not just use a pad made out of treated wood, which would be easier to bolt things on to?
    27' AGP with 6' deep end (AquaLeader); 3/4 hp, 2 speed pump (Pentair); 22" sand filter (Pentair Sand Dollar); 2 4x20 Solar Bear panels with Goldline control valve
    The pump and filter are not usually bolted down, though pumps sometimes are. Concrete is a better choice. Treated wood doesn't always last as long as the pump and filter will, which is a disadvantage. The wood also needs to be rather strong to carry the weight of the filter.
    stever's Avatar
    Nov 2007
    Escondido, CA (near San Diego)
    285
    Re: Mounting a Separate Pump and Filter
    Quote Originally Posted by bobnamy
    I have been told that the pre-fab concrete pads are all going toward the foam-core/concrete coating variety and that these have troubles with breaking in half.
    My PB is using a pad made of recycled rubber (tires probably) that (so I'm told) will last for a long, long tine and can be bolted to. I'll let you know how heavy/stiff it is, as it should be going iin ina week or so.
    Steve
    Pool: 625 SF Free-Form In-Ground Shotcrete Pool w/7.5' dia spa.(8 jets), 24" raised bond beam (22,500 gal)
    Pentair Equip: Intelliflo VF Pump, MasterTemp 400 Heater, IC40 SWG, Quad DE 100 Filter
    Automation: IntelliTouch i7+3 (+ extender panel), 6 Jandy Automated Valves (S, R, Spa Bypass, Solar, Cleaner, Spillway)
    Other: 75% Solar, Kreepy Kruiser Cleaner, Tan Hip-Hop Diving Board (a bit curved) on 606 Cantilever Base (SR Smith)
    Links: [TFP Pool Build Thread] - [TFP Landscaping Thread]
    Apr 2008
    Central Texas
    326
    I would not use the recycled rubber unless there is going to be a concrete pad underneath it. A filter, pump, and plumbing system is HEAVY when it is all full of water. I would be concerned that the rubber would sag over time and cause the PVC plumbing to crack.
    I'm sure it works fine for the year that the PB warranty is in effect, but a pool should last a very long time, and so should the equipment pad.
    26,000 Gallon Gunnite IGP
    2 HP Challenger High Head Pump
    60sf Nautilus DE filter
    Polaris 280
    May 2008
    rock springs, wi
    45
    I can see why you would not need to bolt down a filter due to the weight of the water and sand, but won't a pump have a tendancy to torque and twist upon start-up and stopping, especially when connected with flexible hoses? I assume it will not hurt the pump to be bolted down, as it appears that most pumps I have seen have visible mounting flanges attached to them. I think I will bolt down my pump unless there is a specific reason not too.
    Feb 2008
    Milford, CT
    333
    Ive never bolted down my pump, and its pretty powerful. The base that comes up the pump seems wide enough to offset any torquing that goes on (of which I feel very little, if any)
    I picked up a concrete slab at a local masonry supply house. They had a few different "stock" sizes, I think I ended up with a 2'x4' for my pump and filter. Levelled off a spot of ground, dropped down the slab and put everything on top. I originally intended on drilling holes for the pump, but never have and its never been a problem (and thats with ridgid PVC running directly to the pump.......its never flexed or cracked, so doesnt seem like the pump absolutely has to be fastened down).
    22K IG vinyl, .5HP Northstar pump, S244T filter, AutoPilot Digital w/SC-48 cell
    Mod Squad JohnT's Avatar
    SW Indiana
    9,085
    I don't have either of mine bolted down although both have holes for mounting. I'd be concerned that the bolts would couple the noise from the pump into the concrete. The pump doesn't jump when it starts, and the sch 40 pipe that is connected to it would take a bunch to work it loose.
    Lershac's Avatar
    Baton Rouge, LA
    1,215
    Not Bolted down?!?!
    Let me get a survey going and start writing down names. I will very soon be opening up a used pump and filter store so if any of you have yours stolen, you will know where to come buy a cheap (exact) replacement. HAHA!
    Can't you just see someone cuttin the PVC and lugging those off?
    (DIY):16K Gal 20X30 rectangular IG Gunite, w/spa, CCP 520 filter,2 Pentair VS pumps, 400KBTU Pentair gas heater, Heat Pump for cooling, **update5.25.2013** added an intellichem with acid pump that will control existing SWG. My Build Thread Here
    Feb 2008
    Milford, CT
    333
    It might happen.
    I wish them luck, because I curse the 20' I end up carrying it every year to startup the pool. If they really want it enough to carry it 150' to the road (assuming they want to stay hidden enough to NOT drive a car right onto my property), they can have it.
    Pump weighs a ton.
