Thread: More Calcium hardness
    Please do not hijack the thread. Start your question in a new thread....
    Hi folks,
    Purchased the TF-100 test kit last year.... Opened my pool last Sunday (6-2-13).
    Shocked the pool and ran filter for 24 hours. My wife brought a water sample to Leslie yesterday....
    Here are the results.... (new guy at the testing station without a clue)
    FAC 3
    TAC 3
    CH 500+++++
    CYA 40
    TA 120
    PH 7.4
    Copper 0
    Iron 0
    PHO 300
    When I got home about 6 hours later I tested the calcium hardness myself and got 300....
    QUESTION:
    The kit instructions say "add R-0012, one drop at a time, til color changes to blue"
    I did this and at drop 30 it changed to a purpley blue..... Is that when to stop or do I need to keep adding R-0012 until it turns to a blue..... I always thought it was a signifigant color change....
    Also at Leslie they stoped the test and told my wife it above 500
    any help would be greatly appreciated....... Thanks again
    Vinyl 12 x 24 Extruder 3/4 in ground
    Hayward EC65 DE filter / Hayward Super Pump using one pony
    Frog system (maybe only temporary)
    Aqua Comfort Heat Pump
    Pool Rover Jr. (Best thing I ever bought)
    TF-100 test kit with speedstir
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: More Calcium hardness
    Using the TF-100, I would trust your test results over the pool store's.
    Quote Originally Posted by hggbrew
    Continue adding drops as long as the color continues changing. The final drop that does not cause any further color change doesn't count. For example, say you added 32 drops and the 32nd drop did not change the color, subtract that last drop which results in a total drop count of 31.
    Here are more complete instructions on performing this (and other) tests.
    Extended Test Kit Directions Scroll down to the CH section of this page.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Blue means sky blue. Almost the color of the little box the pH tester is in.
    Thanks guys
