Results 1 to 20 of 20
Thread: Anyone use a water level to install their pool?
    Casey's Avatar
    SW PA
    10,444
    I think I'm going to do this!!!
    http://youtu.be/nAcT_1T25LM
    Jules's Avatar
    Jun 2011
    Kemp, Tx
    111
    Re: Anyone use a water level to install their pool?
    We used one last year, it worked great, our ground was just too hard for us to finish the site. We added a few drops of food coloring to ours, makes it easier to see the water level.
    -Julie
    25,600gal/33' x 52" Sharkline Heritage, Pentair Clean & Clear 150sq ft filter, 1.5hp dual speed Optiflo pump, TF-100 test kit, BBB method, Pool Rover S2-40
    May 2013
    Hudsonville, MI
    29
    The excavator is coming to dig my pool on June 14. One of my projects before he comes is to make a water level! I am going to make a couple of 5' clear tubes that will screw on to my 50' garden hose. This will give me a 5/8" diameter tube and the level should stabilize more quickly. I am going to use wooden yard sticks, stapled to a 2x4 instead of marking the 2x4. I will use zip ties, through drilled holes, to attach my clear tube to my 2x4. This setup should be plenty accurate for leveling a pool.
    18 x 34 Doughboy AGP
    Hayward sand filter(need to look up the model #)
    1 HP Hayward pump(need to find the model on that too!)
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Rent a laser level. Much, much, much easier to use.
    cramar's Avatar
    Nov 2010
    Sault Ontario
    1,143
    2x6 with a 4' level taped to it is also very easy.
    May 2013
    Hudsonville, MI
    29
    John T...I'm curious as to what is difficult about a water level. I haven't actually used one, but it seemed considerably cheaper to make one than to rent a laser for $75/day. I'm on a pretty tight budget here.....
    Casey's Avatar
    SW PA
    10,444
    Quote Originally Posted by jer7440
    Me too! I have everything except the clear hose!
    SW Indiana
    9,199
    It's not difficult, but the laser is extremely easy to use.
    May 2012
    Houma, LA
    104
    I used one. Make sure that you check and double check your water in the hose everytime you move the hose. If you raise the loose end or lower it, the water will come out of the other end.
    It's fairly simple.
    Sharkline 18'X40' Matrix 54 AGP(21k gallons), Pentair Sand Dollar Filter System with 1-1/2HP Dynamo, 125 lbs of ZeoBest., Hayward AquaRite SWCG w/T-Cell 15 TurboCell, Confer Plastics STEP-1 Easy Access Above-Ground Pool Steps, TF-100 Test Kit
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    I used three methods, a lazer to set the pavers, a 2x4 & level to level the ground in arcs off the pavers, and because I dug out for a partial burial and a deep center, I filled the hole with water and watch for high spots. I then siphoned off the water and let it dry for a couple of days. I'm within a 1/4" all the way around.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    joshuaberman's Avatar
    May 2013
    Harker Heights, Texas
    140
    I made a water level and it worked like a charm. What a great tool.
    22'x52" Intex 10,472 gal. w/ 2650 Sand Filter, using Taylor K2006 Kit. BBB
    My Build: http://www.troublefreepool.com/threa...x)-Will-update
    kne's Avatar
    Jun 2015
    Concord, CA
    135
    Quote Originally Posted by joshuaberman View Post
    I know this is an old thread, but what size tube & length did you use?
    18' x 48" Intex Ultra Frame AGP, ~6,500 gal
    Standard cartridge filter and SWG that came with the pool (soon to change!)
    Test kit will all the required juices and powders plus the stir monster
    Jun 2015
    Stockholm, Sweden
    250
    Here is mine: regular garden hose, two jacks and graded tubes. Extremely cheap and easy to use. Leveled all my pavers single handed within 1/4 inch.
    Intex Ultra Frame 24'x12'x52" (732cm x 366cm) rectangular pool
    Intex SF80220RC (1600 GPH) pump/sandfilter
    Intex SF10220 (1050 GPH) pump/sandfilter driving the
    Intex Automatic Pool Cleaner
    Intex 8220 ECO SWG, Brilix XHP100 9kW heatpump
    May 2013
    140
    Quote Originally Posted by kne View Post
    To be honest, I don't recall what size tubing I used. I just went with something I could find readily and would be able to see clearly. I also added food coloring to the water to make it more visible. Nailed a few yard sticks to 2x4s and stapled the tubing to it at the same heights. Voila! Too easy.... hope this helps, sorry for the delay in respinse.
    kne's Avatar
    Jun 2015
    Concord, CA
    135
    Sent from my SAMSUNG-SM-G928A using Tapatalk
    NP about the delay, coincidently I just finally bought the tubing and yardsticks tonight, came home and saw your post. The lowest point for me is an outside edge so I think I'm going to stake one end down level to the ground then have the other end to move around to level. Digging starts tomorrow, depending on weather.
    Your build post is my guideline, love your setup, if all goes well with the leveling and pool filling, I'm going to try and talk my way into a deck this summer.
    Casey's Avatar
    SW PA
    10,444
    Good luck kne! Post pics too.
    May 2013
    140
    Sent from my SM-G925V using Tapatalk
    That's awesome! Glad my thread was useful. Good luck on your project! A lot of work, but very rewarding.
    Mar 2015
    Winfield, KS
    45
    I did the water jug method since I was working by myself most of the time. It worked very well. I think I used 1/2" tubing on mine.
    http://i435.photobucket.com/albums/q.../IMG_09581.jpg
    Round 18' Sharkline pool, 8600 gallons of well water. Hayward 40gpm single speed pump and DE filter
    May 2013
    140
    Quote Originally Posted by Gomez9356 View Post
    Clever. Braced one with bricks when I didn't have a helper. (Which was alot!)
  20. Back To Top    #20
    kne's Avatar
    Jun 2015
    Concord, CA
    135
    I like the water jug. Did the 2 yardsticks, but it required 2 people
