Thread: Can you See Where i should troubleshoot light?
    Jul 2012
    CA
    240
    Can anyone see where the power end of the pool light is at? Light wont turn on an wanted to check voltage to see where my problem is.
    Wanted to use the pool at night.
    Thanks guys.
    [youtube:3cqirmvh]ZVtsD4Yw0j4[/youtube:3cqirmvh]
    25k I/G ecostar ccplus Polaris plaster
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Can you See Where i should troubleshoot light?
    I can't see the video, but the first place to look is behind the diving board or near the light about 5' from the edge of the pool for a raised box. The junction box for the light has to be a foot above the water and at least 5' away from the edge.
    Jul 2012
    CA
    240
    Contacted youtube and they cannot help me, If you click on the "youtube" logo you can view on yotube real quick. Can you idenify brand of niche? its an older pool so should be 120v right? is the swicth connected to that gfi plug outlet right next to? John you da man
    Jun 2012
    western NY
    1,562
    Has this light ever worked? If so, where did you turn it on/off at? That is the first place I would start looking for power. Scratch that, Check the circuit breaker box to make sure all breakers are on then look for a GFCI that may be tripped.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
