Thread: Filter location ?
    Filter location ?
    Good day all,
    I have a 12x24 intex ultra arriving Friday. I will be building a deck along the short side and i would like the sand/salt system to reside under the deck as opposed to along the long side . Can I use extension hoses to make this happen? Flexible or rigid?
    Much appreciated
    mcoonan's Avatar
    Aug 2008
    Mendota Heights, MN
    292
    Re: Filter location ?
    Go with the ridgid. Look at the top of the "Above Ground Pools" forum page and go to "Useful links for fellow Intex Pool Owners" there are a lot of tips and tricks for plumbing there! Good luck and enjoy!
    Intex Ultra 18' x 52" AG 6,981 Gal.
    3 - 2'x20' solar panels
    Hayward XStream 1500 Cart Filter
    Hayward 1-1/2 HP 2-speed Superpump
    Aquabot Pool Rover
    2-Softub 300 hot tubs (yup just got one for the lake)
    TF Test Kit Doing the BBB for 7 years
    Medota Heights,Minnesota
    Got it. thanks
    What about distance from filter system to valves? Is that an issue. Im guessing the filter would be about fifteen feet away from pool intake.
    38,303
    That will be no problem, especially if you use rigid which has less resistance than the hoses ... running 2" PVC will also help maintain the flow rate as well.
