Thread: Can I locate intex sand filter/pump 50-75 ft away from agp?
    john redcorn's Avatar
    Jun 2013
    B.A. Okla.
    64
    It's the cheapest model filter/pump and a separate intex salt system. I just got both rigged up temporarily (sitting on some big rocks and landscaping stones) to an 18' metal frame summer escapes pool today.
    I'd like to put the filter/pump + salt system in my shed with lines running on the ground around the pool this year, maybe bury something next. Lines on ground would be 50-75 feet each, is the 1500 or 1600 gph pump strong enough to keep up or does flat-distance matter all that much? It would be smooth-wall 1.25" vinyl this year.
    Or is a shed a bad idea due to heat? Oklahoma here and the shed is in shade 60% of daylight. I spent $400+ today on a $350 pool and I want this stuff to last since we will surely get another bigger pool when this one wears out. Should I build some little near-pool-located doghouse thing with a fan?
    edit: I've no idea what this tubing costs, when I find out I may be building the little doghouse thing anyway.
    18' Summer escapes with original skimmer + intex pump + intex sand filter w/ Zeolite, Intex SWG. 1x ecosaver 50sqft solar panel with dedicated pump.
    30,432
    Re: Can I locate intex sand filter/pump 50-75 ft away from a
    Welcome to the forum. You are likely asking too much of that little pump. Intex pumps are infamously under powered so I would never take the time to place them where they will probably not work well.
    Jun 2013
    B.A. Okla.
    64
    Thanks. I was at lowes just a bit ago to get a new weedeater and looked at the tubing, close to $2 a foot and I'd need up to 150' not going to do that. I'm going to build some kind of little house for it I guess.
