Thread: Water behind liner bulging this morning
    May 2008
    ottawa, canada
    11
    Hi
    We had a massive rain storm yesterday with hail. This morning we noticed that the liner is bulging all over the deep end of the 20x40 in ground pool. Will the water naturally go back as water outside the pool recedes? The pool is higher than the surrounding area so i am guessing the water will naturally drain.
    20x40 vinyl IGP(120,000 L), with Intelliflow VF Pump.
    17 boxes of Enersol Solar panels,
    Hayward Sand filter, Polaris(Auto-Clear) SWG,
    May 2008
    ottawa, canada
    11
    picture attached
    Dec 2007
    Central New York
    504
    It should. But for my two cents........ leave your pool level high for awhile. You will want the extra water in the pool to help push the liner back into place. It may take 48 hours for you to see any results.
    Hotrod30
    20 X 40 foot vinyl Borates and Salt Pool
    Rolachem Chlorine Feeder
    Hayward 27 inch sand filter with 80 lbs of pea gravel
    Jacuzzi Splash Pak SP55 DE filter in parallel
    Pentair VF3050 pump
    May 2008
    ottawa, canada
    11
    The water has receded and the liner looks fine.
    ivyleager's Avatar
    Sep 2007
    Raleigh-Durham,NC
    489
    Quote Originally Posted by lounge_lizard
    CaryB
    36 x 18 IG vinyl, 25K, 1 HP pump, sand filter
    1 skimmer, 2 returns, no main drain
    Old school: PoolSolutions test kit
