Results 1 to 17 of 17
Thread: Help with opening pool
    Jul 2012
    Caddo Mills, Tx
    33
    I added bleach all winter and kept my pump on. Over the last month, more bleach, vacuuming, and using "boost" function on SWG pump.
    Brownish-greenish residue keeps appearing on floor. Water is blue and clear when splashed. When I vacuum or sweep residue water turns green in area of vacuuming.
    Water tests tonight
    TA-130
    Ph- 8.2
    FC- 15
    Cya - 45
    CC - 0
    TC - 15
    ClBr- dark Orange..... Darker than any color on test kit
    I'm thinking I need to raise CYA levels and lower PH, FC, and TC levels. Not sure what order to do things in. I'm also assuming I have some type algae and will need to shock pool.
    Please give me guidance.
    Shawn
    14,362 gallons - Intex Rectanglar Ultra Fame 32'X16'X52" ABG
    Model SF20110 Intex Sand Filter Pump (Max Working Pressure 50 PSI, Max Flow rate: 2650gal/hr)
    With An Intex Krystal Clear SWG Model CS8110
    Caddo Mills, Tx (20 miles East of Dallas...temps low 20s to 110)
    [b]July 19, 2012 Intsall[/
    30,403
    Re: Help with opening pool
    When FC is above 10 ppm, your pH will read somewhat falsely high so I suspect your pH is a bit lower than that. However, It would be a REALLY good idea to let your pH come down to 10 ppm or so and get an accurate reading.
    Leave your CYA alone.
    "Brownish-greenish" sure sounds like algae and is indicative of your chlorine having been much lower for a period of time.
    I would shock the pool (read how in Pool School) right after I verified my pH level. Lower your pH to 7.4 if the next test indicates pH is 7.8 or above.
    Jul 2012
    Caddo Mills, Tx
    33
    I brought my PH down to 7.2 with muriatic acid.
    FC was sitting at 3.5
    CC 1.0
    TC 4.5
    TA 130
    CYA 35
    Added my bleach. Waited an hour and a half, now I am sitting at:
    FC = 27.5 (oops, I used the mustard algae Shock targets)
    CC = 1.0 (first drop went to an almost clear (very light pink in places), but 2nd drop made test completely clear)
    TC = 28.5
    I've brushed the floor and walls twice since my first test around 9:45pm.
    I only see a little residue on floor in the middle of the pool now. Water has turned to a cloudy blue/green from a light blue.
    What now? Stay up all night keeping FC in shock levels, since I still have 1.0 CC, or go to sleep and start early in the morning with a FC test to see how much I loose overnight?
    Shawn
    Butterfly's Avatar
    South Carolina
    10,045
    Shawn, which one did you do?
    You're done SLAMing when:
    Jul 2012
    Caddo Mills, Tx
    33
    I stayed up the majority of the night checking FC.
    It had dropped down to 25 at 3am.
    At 1030am
    FC 20
    CC .5
    Water looks great but more sediment on the floor in places. Not even cloudy anymore.
    Not anywhere like before, but still there. Going to raise level back to 24 FC and try to keep there all day. I'm going to vaccuum and then sweep.
    Shawn
    Jul 2012
    Caddo Mills, Tx
    33
    close up of sediment on the pool floor. It starts along the seams and corners but then spreads.
    Shawn
    Jul 2012
    Caddo Mills, Tx
    33
    1PM
    FC-24
    CC-0
    While vaccumming I realized my floor wasn't as clean as I thought. I vaccummed and then I swept. Lots of dead bugs floating to top, leads me to believe some of the sediment is just dirt. Green fog here and there, but most fogs were a light grey.
    Shawn
    30,403
    No kidding. Get all that sediment out of your pool and into your filter, then backwash. Vacuum to waste if you have no need to preseerve water.
    Jul 2012
    Caddo Mills, Tx
    33
    Shocking for almost 24hrs now (945pm start time last night).
    CYA 30
    6/7 745pm FC-3, CC-1
    added 427 oz Bleach 8.25%
    6/7 1130pm FC-27.5, CC-1
    6/8 330am FC-25, CC-1
    6/8 1000am FC-20, CC-1
    added 121oz Bleach 8.25%
    vaccuumed, brushed floor & walls, backwashed Filter
    6/8 1pm FC-24, CC-0
    6/8 3pm FC-20, CC-0
    6/8 645pm FC-25, CC-0
    added 2cups of DE to skimmer
    brushed floor
    6/8 745pm FC-22, CC-0
    added 96oz. Bleach 8.25%
    When I brush the sediment comes up, can see where I brushed on floor, and the water becomes cloudy. I'm going to watch FC level to about midnight, adding Bleach to keep FC between 22-25. In the morning I am going to vaccuum to the filter. Been using a self contained vaccuum, but I don't think it is working well, just stirring up the sediment, like the brushing does.
    I don't have a problem vaccuuming to waste and replacing water, but how bad will it mess up my water balance? Pool is large so I imagine I will drop several inches of water while vaccuuming.
    If any of the experts see anything wrong with my course of action, please let me know. I'm thinking my floor sediment has alot to do with the crappy skimmer and inlet that comes with Intex pools. Not enough water movement. I will be using the vaccuum that came with the Intex pool also.
    Shawn
    Jul 2012
    Caddo Mills, Tx
    33
    I went out a minute ago to check my pump PSI and shined my flashlight down the inside of my pool wall. I noticed what I thought were bubbles, from the water line going down about 12-15inches. I took a closer look and it appears to be small black bubbles. They brush off easy and move when touched. Didn't have a feel to them. When touched bubbles came up to the water line. Darker and thicker in some places than others. Were not there last night.
    Is this some type of chemical reaction with an organic or something else? Did a search and saw where someone posted about something similar back in 2008. No one knew then what they were and the post didn't say what happened with it all. Some person suggested they were frog eggs. That person posted pics, but I couldn't get them to pull up (I get the RED X). I'll try and take a pic for all to see.
    Shawn
    Jul 2012
    Caddo Mills, Tx
    33
    Ok, here are the pics. Maybe just bubbles, but they sure look black to me.
    Again, they brush off when touched, and bubbles come to the water line. They only go down about 15inches from the water line. I have been brushing the walls, but not up to the water line.
    Shawn
    Jul 2012
    Caddo Mills, Tx
    33
    One last pic of the bubbles.
    Shawn
    Jul 2012
    Caddo Mills, Tx
    33
    I also noticed that my floor sediment is starting to collect again tonight. I used the "boost" mode on my SWG for three days straight last week.
    The manual said something about having to vacuum up residue from the process. Is it possible that is what some of this sediment is?
    It always starts collecting in the floor liner seams, creases, and corners.
    Shawn
    You mentioned using a self-contained vacuum. Not sure what you have, but when i used an aquabroom, i caught a lot more of the fine sediment if i lined the filter bag with a knee high.
    POOL: Intex ultra new in 2014 (32 x 16 x 52) (seasonal; on concrete pad covered with 1.5" extruded or whatever foam insulation sheets - ugly, but comfy); added a through-wall skimmer; I add salt for feel. EQUIPMENT: Pentair SuperFlo pump (1HP, 2SPD); Pentair cartridge filter (200 sq. ft); Pentair MasterTemp natural gas heater (400,000 btu) Climate/Location: Eastern Nebraska
    Jul 2012
    Caddo Mills, Tx
    33
    Thanks crek31! I actually thought about that earlier this evening too.
    Shawn
    Jul 2012
    Caddo Mills, Tx
    33
    At 9:45pm last night, FC 24, CC-0. At 11am today, FC 24, CC-0. We had a few hours of rain this morning, without sun, so I guess my FC held up to the late morning testing. This means I passed the overnight chlorine loss test!!!!
    Water is clear, but still need to vacuum the bottom. Think I will continue with shocking until I get the pool totatlly cleaned.
    Shawn
    Butterfly's Avatar
    South Carolina
    10,045
    Nice work
