Results 1 to 14 of 14
Thread: OTO chlorine Test (Questions)
    May 2013
    Bay City, Michigan
    283
    I'm just wondering something about the OTO chlorine test.
    In the details of the kit it says "normally used daily".
    I also read in the extended test directions " Above 2 (ppm) accurate readings become difficult and the precision is very low. If its not precise above 2ppm and recommended levels are 3-7, I just can't figure out any time to use this chlorine test. Does anyone use it to decide how much chlorine to add or just as a quick simple look to make sure its not at 2 or less?
    So who uses it daily?
    Who uses it when, why, how often?
    Who says if I'm getting my testing stuff out, I mine as well do the accurate one and do the FAS/DPD test instead?
    12500 gallons, 24 foot round above ground
    Hayward Sand filter, Pentair OptiFlo 1HP 2-Speed pump
    30,403
    Re: OTO chlorine Test (Questions)
    I use it daily. As part of my "Quick" routine just to check that chlorine DOES exist in my pool and that it is roughly at the level I expect it to be....not too dark yellow and not too light yellow. Good enough reassurance for me and, over time, you can develop a more practiced eye so I pretty much know within a couple ppm where my FC is.....the test takes 15 seconds.
    You are welcome to test more precisely and use the FAS/DPD daily and many prefer that. No harm, it just takes more time to complete.
    ship of fools's Avatar
    Nov 2011
    Albany, NY
    495
    I never use mine ..... i found it was not even close to accurate and the FAS/DPD test is so simple i just use it.
    I don't even test daily ...... half a gallon or so of 8% bleach every day and i am all set
    21,000 gallon inground
    Haywood Sand Filter
    Vinyl Liner
    Jun 2007
    New Jersey
    653
    I never use it, either. I know if I have any chlorine before I test, because I stay on top of my levels. I always do, unless something has gone wrong, and in that case, I need to know the exact number. So OTO is pretty much a useless waste of time for me. Plus I get to use my SpeedStir with the FAS-DPD.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
    Butterfly's Avatar
    South Carolina
    10,045
    The OTO is a bulletproof test for the presence of chlorine.
    You're done SLAMing when:
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I am also in the rarely use it camp, I use the FAS DPD wtih speed stir, usually every other day or so, but I do have automatic chlorine injection. On occasion I will run it as a sanity check against the FAS-DPD test though.
    30,403
    msgtdan's Avatar
    Jul 2011
    SW MO
    653
    I use the OTO as a cross check and under certain conditions to see if I need to do the FAS check. Example: day before yesterday I was weed eating around the pool and saw some of the clipping go into the pool so I took FC up to ~10. I then put the solar cover back on and left it. Yesterday was cool and overcast when the OTO read higher than 5 FC I just stopped there and left it alone. We have similar conditions here today, so tonight when I check if it's still over 5 I'll walk away from it again, if not I'll test with FAS and see how much it needs.
    Dan D
    Used 2003 Aqua Leader 27'x52", 17,800 w/10" hopper, SwimPro SW256T 250# sand filter, Hayward PowerFlo LX pump 1hp impellor, Emerson 1 1/2 hp motor, setup Aug 2012 Summer 2011 used Summer Escapes Ring pool 14' x 42", Intex 1600gph sand filter, HTH 6 way test kitTF-100 w/stirrer, Well water @ FC=0, PH=7.2, TA=290, CH=320
    Nov 2011
    Albany, NY
    495
    I forgot to add that mine is woefully inaccurate ...... it might read 1 or 1.5 when the chlorine is 5 or 6.
    I got all scared and nervous one time that my chlorine was so low (and i was so off base ) then i used the fas/dpd test and i was dead on.
    Haven't touched it since
    Haywood Sand Filter
    Vinyl Liner
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,943
    I use OTO and pH tests daily, then FAS/DPD and other TF100 tests (except CH and CYA) weekly. Those two tests only about once a month.
    chiefwej
    30,403
    Nitpicking a bit here but it is difficult for the OTO to be extremely inaccurate. It is usually lack of experience and practice with that test that makes it hard to judge. I can easily get withing 2-3 ppm and that's w-a-ay good enough for the purpose for which I use it.
    Jun 2007
    New Jersey
    653
    Quote Originally Posted by msgtdan
    Relax. Both my pools, going back to 1946, have had grass growing up to within a foot of the water. Lots of clippings go in every time I mow. I never shock, ever, except at open. Grass may be green, but it's not algae and doesn't seem to eat much chlorine.
    Nov 2011
    Albany, NY
    495
    I posted about this way back when it happened and if i remember correctly it was suggested that i may have had weak reagents ...... in any case i just do the fas/dpd test which takes me all of 1 minute
    Haywood Sand Filter
    Vinyl Liner
    Nov 2011
    Albany, NY
    495
    Here is my post from way back
    large-discrepancy-in-cl-tests-t46507.html
    I read 0 on the OTO test and 4 on the FAS/DPD
    Haywood Sand Filter
    Vinyl Liner
