Thread: EcoStar water in pump lowers down and returns start to bubble
    Okay. I just had installed new Ecostar 3400 and the same problem.
    I found his forum after extensively searching for solution.
    After priming and pump running on low for about 6-8
    hours level of water in pump lowers down about 1-1.5 inch and returns start to
    output air.
    On the high rpm air disappers until rpm falls.
    Builder swears there no leaks in the system and states to check with Hayward.
    Internet messaging boards do mention this problem quite often.I
    I did all basic troubleshooting like checking O-rings, using Jack 123, teflon tape, etc. Nothing
    helps. It looks like it is dynamic suction side leak which disappear
    on suction increase or else. Does not look as piping problem which would have opposite effect.
    Did anybody found a solution?
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: EcoStar water in pump lowers down and returns start to b
    Mark
