Results 1 to 12 of 12
Thread: correct or incorrect?
    Sep 2012
    Ramsey, NJ
    15
    Hi,
    My pool builder replaced the coping on my pool with stone but put tile on the side where the pool cover is. Now, when i swim, water empties into the cover recess. I spoke with the builder and he told me that the tile is on the same level as where the coping was, and that I need to top up the pool with water from the hose when the water level falls.
    The builder has almost finished with the pool. Has he done the tile correctly? What options are out there to prevent the water from flowing out like that?
    Thanks!
    Nikolay
    40K gallons in-ground, plaster, square pool. DE filter. 1.5HP Hayward pump. 0.5HP Booster Pump. Spa. Brick pavers patio. Mesh pool safety cover.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Re: correct or incorrect?
    Are you keeping the water level at the same spot, before and after? Seems like the only difference from the pictures is that with the tile there is a more gradual slope, vs the hard edge of the old coping. New coiling looks like concrete....
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    From what I can see in the pictures the old coping was tight to the track at the water line, while the new tile surface is well below the track at the water line, sloping up gradually towards the track in a way that encourages water to go over the wall. The old coping also appears to extend out a little over the wall, which would have helped prevent splash over.
    Sep 2012
    Ramsey, NJ
    15
    The water level is not the same, as i didn't care about it before. You have to kind of look at it from the rail down.
    Any advice on how i should discuss the problem with the builder and how it should be corrected?
    Sep 2012
    Ramsey, NJ
    15
    The new coping is Tennessee Crab Orchard. The pattern is nothing like we saw on the pictures they showed us, but then again nobody wants to guarantee a pattern.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Seems to me, as I understand autocovers, the original water level should be respected, that level is what was used to calculate the extra slack in the cover material. So if you raise water level no problem, but if you lower it their could be issues, because that was accounted for in cover measurements.
    18'x43' Sport Pool
    Sep 2012
    Ramsey, NJ
    15
    Thanks for the reply, but how that does resolve the issue with the water overflowing into the cover recess?
    Feb 2011
    Petaluma, Ca
    665
    Most I've seen here and including mine look like your second picture. It's hard to see that the water level is different between pic 1 & 2. When just one or two people swim almost no water is lost unless you jump in and make waves, when there is a lot of action / people you can count on losing water into the cover vault, there is nothing you can do. I kind of like the original design with the lip as it seems like it would minimize the splash out but I don't think anyone does it like that now. Overall my guess is approx 1000 gal lost each time I have a large gathering, but when it's just me nearly nothing.
    DONE, 20 x 40, inground gunite, 30" raised bond beam with 3 12" sheer descents, 8' diving board, pentair 420 cartridge filter, vs-3050 pump, intellechlor ic-40, auto cvr, Tahoe blue pebble tech, 6ea 4' x 12.5' & 2ea 1' x 12.5' helicol solar panels, legend robotic cleaner.
    Sep 2012
    Ramsey, NJ
    15
    Thanks for the reply bobby!
    I actually did four laps last Saturday and that's when I noticed the water overflowing into the recess. It was just me, swimming back and forth. Then my brother got into the water, and it got worse.
    Any suggestions?
    Feb 2011
    Petaluma, Ca
    665
    One thing that is a little different, when my cover is retracted the front bar isn't as far back as yours, at the most I see only the first row of tiles. Even though it doesn't "seal" I think it helps somewhat to keep the water out of the vault, once you have more people / waves water will go in under the bar no matter what.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    What brand covers are ya'lls? My setup is nothing like that. My cover rolled up is on top of the pool wall, the pool wall by the pit is the same as it is all around the pool. Meaning i have 5-6" of wall above water level, and then the end of the pool cover on top of that. I don't get any (or not measurable) water in my pit from swimming.
    Sorry i don't have any suggestions. I guess it has that slope to prevent wear and tear on underneath side of the liner.
    Best picture i have.....
    18'x43' Sport Pool
    Feb 2011
    Petaluma, Ca
    665
    Mine is from "cover pools". I like your design, I didn't really look around and just got what they gave me when the pool was built, all I asked for was an "auto cover". I wasnt smart enough to join here 1st and learn some things before quoting. Overall I'm happy but there could have been a few improvements.
