Results 1 to 9 of 9
Thread: Bleach Dilution Question
    May 2013
    North East Ohio
    959
    So I really did try searching, but too many posts to dig through, so hopefully this is a easy YES
    I am going to be using Chlorine (bleach) via Stenner Pump for my pool.
    Since lower concentrations have longer life in sun, can I just buy 12.5% (can get a good deal locally) and dilute it 50% to get approximately 6% solution. I will then load my 15 GAL tank with 6% and dose accordingly.
    I am fairly certain the answer is yes, just looking to verify.
    Also, IF I AM OCD and most likely I will go through 15 GAL of 12.5% long before is starts to weaken, yell at me as well.
    Thanks again in advance.
    14,750 GAL IG Fiberglass (16 x 33) NE Ohio || Jandy 1HP 2 speed Pump || Waterco MultiCyclone 16 Centrifugal pre-filter (removed due to not working with sand filter) || 30" 575 Lb. Sand Filter || AquaCal 140K BTU Heat Pump || Solar Cover || Inter-fab Adrenaline Slide || GLI Monsoon Solar Cover Reel || K-2006C Test Kit || BBB with Liquid Chlorine Stenner Injection || Rayner Mighty Mesh Winter Cover
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Re: Bleach Dilution Question
    Why not provide shade?
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Dilution is not generally a good idea. The water in bleach is specially filtered to remove low level contaminates that can shorten it's self life. Tap water does not have equivalent filtering and could significantly shorten the shelf life (or not depending).
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,046
    Quote Originally Posted by toofast
    Here's an idea: buy an ice chest to use as your chlorine tank. Then it's insulated.
    May 2013
    North East Ohio
    959
    Wow, so glad I asked this question...
    I am using the Stenner tank, which is UV Resistant...I will also do my best to build in some shade.
    Thanks gang for the quick responses.
    So - final question then....if I can get 6% and 12.5% at the same relevant cost (meaning once adjusted for strength etc) it seems like it would make sense for me to use 6% in the Injection system.
    That depends on how much you mind carrying jugs
    May 2013
    North East Ohio
    959
    Ok, say I LOVE to carry jugs of bleach
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    LOL!
    18'x43' Sport Pool
    Isaac-1's Avatar
    SW Louisiana
    6,711
    6% is likely to be gentler on the pump parts, tubing, fittings, etc. even if they are made of material that is acceptable to handle chlorine.
