Thread: Help me remember how to use theK-2006 test kit
    Pool after testing is showing no FC PH is 7.9 and Alka 140 ppm pool is cloudy and a little (very little) green. Hubby is just using test strips which shows everything fine...........well obvious it's not thus the color and cloudiness....he just keeps dumping shock and baking soda for no reason....HELP!!!
    What is normal PH and ALKA?
    Thanks!
    15 x 30 oval above ground, 13000 gals, 1 HP pump, sand filter.
    38,470
    Re: Help me remember how to use theK-2006 test kit
    Have you review Pool School? Everything is still there in the articles.
    Baking soda is a BAD idea since the TA is already pretty high.
    If you have the K2006, why did you not post a full set of results:
    Extended Test Instructions
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    http://www.troublefreepool.com/pool-...mmended_levels
    pH should be 7.2 - 7.8 Lower end is better for the shock process.
    TA should be roughly 70 or above. If it's over 120, don't increase it any.
    Green water means algae which means bleach is needed. Lots of it. The shock process.
    http://www.troublefreepool.com/exten...ns-t25081.html explains the tests in detail.
    Also, lookee here: videos! http://www.youtube.com/user/TF100TestKit
    Have you seen this thread? help-me-not-murder-my-husband-t61480.html
    [center:1zkrgffi][/center:1zkrgffi]
    TY for the answers
    Quote Originally Posted by Richard320
    [center:2qibkvfm][/center:2qibkvfm]
