Page 1 of 4 1234 LastLast
Results 1 to 20 of 70
Thread: New kit! Real numbers. Now what??
    Jun 2010
    Dayton, Ohio
    241
    I have a cloudy pool. I can make out liner pattern, very cloudy blue. I have been trying to keep at shock level for 2 weeks and vacuuming and brushing. Today I got my new kit!!! Here are my numbers.
    FC 13
    CC 0
    pH 7.7
    TA 180
    CH 240
    CYA 35
    I think I keep pool at shock level until I have clear water and pass overnite test? Should I keep FC around 14 or 15? Soooo happy with my Taylor K-2006!
    AGP: 24' x 52" cartridge filter: 13,500 gallons. Taylor K-2006 test kit.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: New kit! Real numbers. Now what??
    Yes.
    That was easy, huh?
    Don't forget to brush, including under the ladder rungs and maybe even inside the legs.
    Jun 2010
    Dayton, Ohio
    241
    I have wedding cake steps and haven't even put them on. I think numbers look good. The walls won't come clean when I brush they feel like sandpaper. What is that? Calcium build up? What do I do with it?
    Calcium scale is difficult to remove. Generally you have to drain and manually acid wash.
    You are probably getting calcium scaling because your TA is high.
    Jun 2010
    Dayton, Ohio
    241
    Well I can't really drain the pool, it comes off if I scrub it. Very labor intensive. I need to lower my pH wirh acid in order to lower my TA is that correct?
    30,401
    There is a good article in Pool School on lowering TA
    Jun 2010
    Dayton, Ohio
    241
    Thank you! I guess I new to get to work.
    Jun 2010
    Dayton, Ohio
    241
    My numbers this morning are
    FC 16
    CC 0
    pH 8.0
    I know pH is high but shouldn't I be ignoring that while I am shocking?
    30,401
    Yes
    Jun 2010
    Dayton, Ohio
    241
    Awesome I think I am getting the hang of this. Now I'm not shooting blind. Water cloudy so just gonna keep it up.
    Jun 2010
    Dayton, Ohio
    241
    If my CYA is 35 should my normal level of FC be at 5 after I pass all three criteria for stopping the shock process?
    38,235
    Sure ... your minimum will be 3ppm, you will have to target 5-6ppm to make sure it does not drop below 3ppm by the next day.
    Jun 2010
    Dayton, Ohio
    241
    Thank you! My CYA fell in the middle of the chart so I wanted to make sure because I know how important it is!
    Jun 2010
    Dayton, Ohio
    241
    I ram the overnight test last night.
    Last night
    FC 15
    CC 0
    This morning
    FC 13.5
    CC 0
    Water almost crystal clear. I will keep it up. Next step I guess is tackling scale deposits all over liner walls.
    Jun 2010
    Dayton, Ohio
    241
    I added half a gallon of muriatic acid and tested few hours later.
    FC 15
    CC 0
    pH 7.2
    TA 70
    CH 70?
    Very confused my CH it was 220 yesterday morning. I tested exact same way. Did I mess up?
    38,235
    You must have messed up one of the 2 tests at that is not really possible.
    Jun 2010
    Dayton, Ohio
    241
    Think I should do it again? So bizarre I feel like I did it exact same.
    38,235
    CH is not really that important for a vinyl pool ... and neither of those numbers are high ... so up to you.
    Jun 2010
    Dayton, Ohio
    241
    Not real concerned about CH but I do have some really bad calcium deposits on walls. Lowering pH and TA can help that right? I can't drain pool.
  20. Back To Top    #20
    38,235
    Yes it can help to maintain a negative CSI (see the calculation in poolcalculator) and brush a lot.
