Thread: Water level very low
    Jun 2011
    Ontario, Canada
    20
    The water level in my still closed pool has dropped significantly. The only thing that has been done this season is water pumped off the cover (by FIL while I was at work); besides a hole being present on the cover, is there any other reason the water level would drop?
    I closed the pool and know I did it right.
    Thanks.
    24k gal (100k L) inground vinyl|Watermaid EZY SWG|Hayward 1/2 hp & sand filter
    38,361
    Re: Water level very low
    You have either been pumping the water out from the top of the cover (if there is a hole you are likely draining the pool while doing this)
    OR
    you have a leak.
    No other options really.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Several people have commented that they found lower than expected water levels on opening, and some have noted having a dry and windy spring which might account for increased evaporation rates in their region.
    redhdgirl417's Avatar
    Sep 2012
    Mid-Michigan
    127
    My water was a good 6" lower than what I lowered it to last fall when I opened last month...I did have to pump quite a bit off my cover and I know some of that was pool water that seeped through the weaved winter cover plus evaporation.
    13,900gal 24'x52" Backyard Leisure Heritage AGP
    20ml All Swirl Flat Liner
    Pentair 1.5hp Pump and 150# Sand Filter System
    Smart Step Ladder w/Smart Light
    TF100 test kit, BBB Baby!
    Jun 2011
    Ontario, Canada
    20
    Thanks for the replies.
    I can understand the pump/hole-in-cover scenario, and I'll inspect the cover for a hole.
    As for the leak scenario, since level was lowered below returns and lines were blown and sealed, would this mean I have a leak in my liner?
    Sep 2012
    Mid-Michigan
    127
    Quote Originally Posted by saysomething
    My water was also drained below returns and still lost more...it happens. I believe there is a bucket test you can do for possible leaks.
