Thread: Pool open for business!
    Apr 2013
    West Des Moines, Iowa
    14
    Been a long slog - 30 days of raking, vacuuming, skimming, adding chems.
    25K Gal L-Shape in-ground Vinyl Pool;1 bottom drain - 2 Skimmers, 1.5 HP Pentair pump, Sand Filter, Heater, Liquid Chlorine
    38,283
    Re: Pool open for business!
    Looking good
    If you follow the recommendations for closing at the end of the season and open early enough (based on water temp), you should not struggle so much next year.
    Apr 2013
    14
    Thanks. We bought the house in December. The pool was closed by the previous owners and was put away green and full of leaves - about 6 bushels wet. Been running shock level chlorine levels for the past few days to clear up (hopefully) the last remnants of the organics. I should send them the bill for all of the extra chlorine I have had to add!
    Casey's Avatar
    SW PA
    10,438
    They should have just left the cover off!
    You did a great job cleaning her up! We'll help you get her to bed this fall!
