Results 1 to 7 of 7
Thread: Best ways to weigh down pool ladders???
    May 2012
    Small midwest town In illinois
    55
    I am sick of dealing with the sand bags to keep my stairs weighted down in the pool. They are messy and a pain. Can anyone recommend a better or easier way of doing this. The cheaper the better!
    14,600g / 24ft. Round Above Ground with Solar Cover and solar heater panel.
    Vinyl Liner
    Hayward Cartridge Filter (CCX 1500RE)
    2 HP Hayward Powerflo LX Pump
    Pool and solar heater get full sun, when its shinning daily!!
    Using test kit: Taylor K-2006
    Successful BBB user.
    22,551
    Re: Best ways to weigh down pool ladders???
    PVC pipe filled with ssand and water and capped.
    Smykowski's Avatar
    Sep 2011
    3,065
    Or concrete, that's what I did.
    redhdgirl417's Avatar
    Sep 2012
    Mid-Michigan
    127
    Use 2 45# retaining wall blocks in space bags. Our stairs have a shelf built in bottom so they just sit on it.
    13,900gal 24'x52" Backyard Leisure Heritage AGP
    20ml All Swirl Flat Liner
    Pentair 1.5hp Pump and 150# Sand Filter System
    Smart Step Ladder w/Smart Light
    TF100 test kit, BBB Baby!
    May 2013
    Arizona
    112
    If u have a auto food saver ( sold at walmart, sams frys) they use sturdy plastic bags and auto vac seal it while sucking out ant air to keep food from freezer burn etc. Get the largest sized bags seal there sides with the heat seal option then fill with sand then seal the final side its 109% waterproof tben u can weigh it down by tying it securly to the bottom of your ladder works like a charm. It always works great if u r using one of those over the side skim baskets they hang by a flat piece of metal that goes over the rail. They have a terrible tendency of bobbing up and down and therefore spilling whats in it. Two options there 1. Same thing use smaller bag place sand yet before u seal the final side add a sturdy piece of string or fishing wire works great seal the bag with 1 inch of string inside and as much as u need outside to tie to the floating skimmer. 2. Can use smaller bag first tie fishing wire to a small fishing weight ( fisberman using them to weigh down the bait) this is easy to do because the weight has a hole already in it for this exact purpose make the bag just big enough to fit the weight seal three sides first leave enough fishing wire out of bag to tie to basket then seal the last side with wire sticking out. ( since fishi g wire can melt cover the bit u want outside the basket with a tripled up papertowel so tge outside wire wont melt. The part that isinside willmelt right where it makes its heat seal that makes the conne tion inside the Bag great and perm. The weight is metal which is y u want to seal it the chemicals from the pool will cause it to rust. Married to a avid fisherman ave beach house in nags head nc,so i know all about the weights. Dont leave to much wiring hanging from basket put it maybe three inches hanging get someone to tie a nice fishermans salt water not stream knot. Good luck hopes it helps...product is called A food saver. Plus they r great for keeping your foid fresh long time
    I filled my empty bleach bottles with quickcrete and let them set open for a couple days to dry out and harden/put cap on & zip-tied them by the jug handle to underside of stairs (i have slats on side that zipties worked great on. Worked great for me! Can cut zipties and remove at end of season to lift stairs out if needed.
    Lizzieann,
    27x54 AGP with Waterfall, 18,500 gallons, Waterway Sand filter- Waterway 1.5 hp -1 speed pump , TF-100 test kit, BBB method.
    May 2013
    Arizona
    112
    Wow thats a good idea too no worried it might rip liner? I love this place so many great ideas
