Thread: Chlorine is way too high
    My chlorine levels were at zero so I added chlorine and now they are way too high. Is there a way to lower them within a few hours or do I just wait?
    38,475
    Re: Chlorine is way too high
    Welcome to TFP!
    What makes you think the chlorine is too high? Why do you need it lower? What is your CYA? Post up a full set of test results.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Quote Originally Posted by sunnireilley
    Welcome!
    Well...if the pool is green and swampy, it's probably not too high anymore. And if the CYA level is low, a couple hours in the sun will fix it.
    There's really only two choices: drain, or wait. I'd wait.
    Now, then...how much did you dump in and why?
