Thread: How to level the pad without permanent damage
    Our pool is on our way and we too were looking for the footprint so we could get started leveling. Our entire 2 acre property is on a slope and leveling is very hard. We have decided to put this on our very large back porch. However our porch is also at a slant (about 2 inches) for water runoff. We were going to frame it with 2x4s and use sand to level. Has anyone else done this on concrete? We know the concrete is thick enough to withstand the weight of the pool we just are not sure about how to level the pad without permanent damage.
    30000gal, IG, Painted concrete, ~1940. Current equip plan, comment welcome!
    Jandy SHPM2.0-2 2HP uprated (60ft/100gpm), Hayward S310T2 Pro Series Top Mount Sand 30in. (possible zeolite?), CompuPool CPSC48 SWG, 2 skim, 1 drain, 1 vacuum (Kreepy Krauly Kruiser).
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: How to level the pad without permanent damage
    You might try contacting a concrete contractor in your area, there are certain products like thin set concrete that are designed to be poured over existing unlevel slabs to fix such problems.
    Ike
