Thread: plaster startup
    Apr 2012
    151
    plaster startup
    I have a friend whose pool I will end up taking care of. I have been watching her build, and it has come to the point that I am about to be brought in to train her on care. I know that the builder she used is top notch, but when I asked her what was done to start the pool, the response was nothing. Just filled with water.
    The pool filled Saturday. Is it too late to do a bicarb start?
    Science and Math Teacher
    Owner - SPS - part time pool biz
    18x36 IG Vinyl, 23000 Gallons with Jacuzzi (the bane of my existance) pumpworks
    Polaris 280 w/ PB4 booster
    Jul 2011
    Arizona & California
    803
    Re: plaster startup
    Provide the current water test results pH, TA, and CH, and let's see what may be needed and can be done.
    Apr 2012
    151
    Re: plaster startup
    Cl 3.6
    CC .2
    pH above 8
    TA 290
    CH 50
    CYA 0
    Salt 0
    Water is cloudy.
    Jul 2011
    803
    Re: plaster startup
    The cloudy water could be from not filtering the new water, or from "plaster dust." Get the filter running (if not running).
    The TA is high, so therefore, the Bicarb start-up has been partially performed by the fill water. No need to add more Bicarb.
    At this point, keep the chlorine additions going, and add acid to lower pH to below 8.0. Once that is done, add calcium chloride to raise the calcium level to at least 150 ppm. Do not add calcium chloride until the pH is below 8.0.
    Then follow the TFP guidelines (Recommendations) under Pool School, and brush the pool twice a day for two weeks.
    Apr 2012
    151
    Re: plaster startup
    Cool. Just what I thought.
    Thanks for the prompt response.
