Results 1 to 12 of 12
Thread: When do you add bleach? evenings?
    Jun 2012
    NJ
    40
    I think I read that most of you test and add the bleach in the evening each day. How long do you have to keep the pump on after that? In the past we have set the timers to run the pool during the day so now I am thinking of changing the timing.
    NJ
    35,000 gallons, DE filter, IG plaster
    TF-100
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,609
    Re: When do you add bleach? evenings?
    Run it for 30 minutes to an hour and you're good to go.
    Samantha_in_AL's Avatar
    Apr 2010
    Altoona, AL
    242
    I suppose you can add bleach any time of day. I add mine in the evenings when I'm working because it's easier for me. I add it in the morning on weekends and when I'm off work.
    AG 18' X 52" Round Pacifica Pool w/ Metal Diamond Unibead Liner. Installed in March 2007.
    2.5 HP Baquapure 2 Speed Pump, 200 GPM Waterway ProClean Cartridge Filter System.
    Former Baquacil user
    Converted to BBB in Fall of 2009 - Now I have a truly trouble free pool!
    May 2012
    North of Charlotte, NC
    312
    I have mine set to inject when the pool pump starts in the morning...for 1hr then shuts off, then the pump shuts down after a 5hr run,then off for a couple Hrs , then restarts in early afternoon for another 5hr runtime and the 2nd 1hr injection...works for me so far... But been contemplating running once during the mid morn/early afternoon then the second time at night??
    Curious what other folks are doing...
    24,000 Gallon Vinyl Grecian IG,Triton2 Sand Filter / Pentair Super Flo 1 HP Dual Speed Pump ,
    Stenner Peristaltic Pump Injection w/15 gal drum,Stubbed up supply/return for future solar panels :)
    TF100 Rocks !! Pool School....
    Jun 2007
    New Jersey
    653
    I run 7-10AM for skimmer action to clear the surface and 7-10pm to give me circulation after chem dosing (usually between 7 and 9). Seems to work. I like having the highest ppm of bleach during the night so that it can work away before the sun starts to erode it the next day. At least, that's my theory. We always dosed at night during the pre-CYA era so it is sort of ingrained.
    Current: 28,000G 18'x36' I/G AnthonySylvan Plaster; Waterway 60 sq.ft. DE Filter; 1.0hp x 1.65 SF Two-Speed (B2982) WhisperFlo; 2004-Present
    Previous: 40,000G 20'x40' I/G Koven unlined WWII salvage 5/8" marine steel; Lomart Stainless Sand Filter; 3/4hp Hayward SuperPump; 1946-2003 (managed by me from about 1964)
    Ancient Taylor K-2000, upgraded with Taylor CH, TA, and FAS-DPD, and TFT CYA tests.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    I add bleach in the early evening, ideally as soon as the sun is no longer hitting any part of the pool. I run the pump for about 30 minutes after dosing.
    Evening, I run the pump probably 22 hours a day, convenience is the only reason I don't run it less.
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    Jul 2012
    Seymour, In
    49
    I am like most, I add mine in the evening after the sun is down enough to be off the pool. I start the pump around 3:30pm and let it run until around 9 or 10pm. Depending on how much sun we have had and the swim load. This seems to work for us so far but this will be the first full summer with our pool. Installed very late last summer and was only open about 6 weeks before closing up.
    24x54 ABG 15,200 gal, 22in Ecco Sand Filter, 1.5HP Ecco pump
    Feb 2008
    Denton, TX
    5,061
    Evening once the sun is down. Lose less of it to sunlight that way and you get more of your money's worth.
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    334
    Does the pump need to run a certain time before you test?
    ~15k gallons, 3'-5'-4' Figure 8 Shape In Ground
    Wetedge Satin Matrix Interior (Pebble)
    Paramount In-floor System
    Pentair IntelliFlo VS 3050, Pentair Triton II TR100 Sand Filter
    Pentair Intellichlor IC40 SWG
    Jul 2012
    Seymour, In
    49
    I think most will say let it run at least 30 minutes up to a hour before testing again. I usually wait around a hour before retesting.
    tcat's Avatar
    May 2012
    Austin, TX
    731
    I run my pump from 1PM to 6PM. It "sucks' bleach from a bucket for 5 hours. I have it tweaked for 30-32 oz over that time. FC is always over 3.0, gets to 5.5 at times. I wouldn't think it would matter what time, it's going to go down "x" amount, you need to raise it "x" amount.
    IG pebble, 15,000 gallon
    48 PentAir DE Filter with backwash valve
    PentAir Whisperflo pump with 1hp 2-speed motor
    Aquabot 4WD, Poolskim
    Intermatic Dual Timeclock with freezeguard
    DIY chlorine feed
    BBB
