Thread: How to tell when SWG is not making chlorine
    In-ground pool, about 23,000 gal. system. I can't get FC up to spec. with my t-9 Goldline system. I get zero chlorine with drop test but did get a normal reading at the jet, but should the jet show a high chlorine level when system on superchlorination? My CYA seems on low end. PH about right. Trying to decide if generator is failing. Voltage and amperage is just out of manual stated ranges but probably within tolerance.
    Apr 2013
    Central Massachusetts
    174
    Re: How to tell when SWG is not making chlorine
    Here's one way: Turn it off, get your pool "sparkling" by following the shocking process using liquid chlorine and finishing with the overnight FC loss test. http://www.troublefreepool.com/pool-...rnight_fc_test
    Then the next night turn on pump and your SWCG high enough that it will generate chlorine. Measure the next morning. With no sunlight and no organics consuming chlorine, your FC level should have risen if your SWCG generator is working. You should be able to calculate how many ounces of chlorine were generated even.
    26,000 gal 18x36' IG Vinyl Pool - Hayward S244T Sand filter - Hayward Tri-star 2-speed 1.5HP pump - Goldline Aqua Plus SWCG and Controller with Tcell-15 - Aquacomfort 125K BTU Heatpump - Hayward Color Comfort 4.0 LED - Zodiac MX8 suction cleaner - TF100 test kit
    My Build thread
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome to TFP!
    Quote Originally Posted by luvbigiron
    , including what your CYA level is? Depending on how "low" it is, that could be part of the problem. It is quite possible that your SWG is working fine but that the FC is being consumed by sunlight at a high rate due to a "low" CYA.
    It also could be that you have something organic living in the pool that is consuming FC at a high rate. Test results will help us confirm that. Also, how does the water look?
    One other thing...Please put the city and state (or country) in which you live in your profile or in your text. Your climate is important to the advice you receive.
