Thread: What do i do?
    What do i do?
    18x52 round intex pool with swg
    Filled pool sunday added 175 lbs of salt 1.7 lbs of cya in a sock.Have run the swg a filter for 2 days now. 3 hours for the swg and 6 hours for the filter.
    here are my test results today.
    FC .5
    PH 7.2
    alkalinity 80
    Hardness 120
    CYA 0
    i am using a hth test kit.
    please help
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    Re: What do i do?
    Bring your initial level of FC up with bleach and then use the SWG to maintain. CYA won't show up on a test for about a week. Welcome to the forum.
    Re: What do i do?
    The intex pool book says to add 1.7 lbs so i put it in a sock but it dosent seem to be dissolving very quick. I just moved the sock in front of the water jet today to help dissolve it. Im not quite sure how much bleach to add. This might sound stupid but the pool calculator is kinda confusing. Do i want my FC level at 4? And the hth test kit says chlorine/bromine test is that the same as FC?
    Re: What do i do?
    And thank you for responding and welcoming me to the forum!
    Apr 2010
    East Texas
    9,659
    Re: What do i do?
    You can use the pool calculator in pool school to get the number of gallons for your pool size. Then put that # of gallons in at the top. Then punch in 0 for FC starting point and 4 as your target and let it calulate how much to add of 8.25% bleach, which you'll have to put in the calculator manually as it has not been updated for the new %. Gallon or so is a good guess.
    Apr 2012
    SW Ohio
    456
    Re: What do i do?
    I have the same pool and I use 7000 gallons capacity and as far as the cya not dissolving a little trick to help it along anytime your near it just give it a few squeezes.
    18x52 intex ultra frame pool 6981 gallons, 1 HP LL pump with 19 in sand filter,BBB method,borax 50ppm
    leslies DPD test kit + fas-dpd chlorine test kit + borates test strips
    thru wall skimmer,hard plumbed with 2 returns 1 1/2 sch 40 pvc
    1 large fountain 1 inch sch 40 pvc,shut off ball valves on all
