Results 1 to 15 of 15
Thread: gotta chlorine problem
    Mar 2013
    Waco,Tx
    43
    Now bare with me. Ive been testing my water on my own for a lil while now with no issues. On Saturday I noticed it get just a little cloudy. It was a little low on chlorine.
    FC 2.5
    CC 1.5
    TA 120
    PH 7.5
    CYA 60
    So i brought it up to shock about 25. Checked next day(Sunday) and it was FC 23.5 and the CC .5 Checked twice today to back up my reading. The first time it was FC 8.5 and CC 1.5 and then FC 10 and CC 1. I am not doing anything different. Use the same amount of powder etc.........I cant believe that I would lose that much chlorine. I can see the bottom. Theres no dirt or anything in the pool. Its just a little hazy. Really no different than the way it was when I was dealing with the pool store. But ive had it crystal clear and im, not sure whats goin on. Need some help
    32k gallon Inground lazy L with Vinyl Liner. Pentair Superflo 1.5hp pump with a sand filter. Liquid Chlorine
    Butterfly's Avatar
    South Carolina
    10,045
    Re: gotta chlorine problem
    Your test results tell us that you need to follow the shock process in Pool School. Link in my sig.
    Post back with any q's and we'll help.
    You're done SLAMing when:
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Quote Originally Posted by Sack
    FC 2.5
    CC 1.5
    TA 120
    PH 7.5
    CYA 60
    The cure is the shock process.
    The cause is low chlorine for your CYA level. It should never dip below 5.
    To prevent it happening again, aim a little higher on the target to pad the FC. Then if you get an exceptionally hot day and/or a bunch of swimmers, you have that cushion to keep FC up.
    Mar 2013
    Waco,Tx
    43
    I have followed the shock process. I am aware I let the chlorine dip thats why I shocked it when the CC was high. Yesterday the readings were fine and today its back down.. It did get fairly warm today though.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    I would do a OCLT tonight and see where you are at.
    Mar 2013
    Waco,Tx
    43
    So my chlorine readings are inconsistant. I was trying to bring my chlorine level up to shock again last night. Before I did so FC was 16.5 and CC 1 I added 4 gallons of chlorox which according to the chart should have brought it up to 26. The pool circulated for 3 1/2 hours and i tried to check before bed. The reading was way to high so I never got a reading. Is that enough time to circulate before checking? Got up this morning and checked it and the FC 35 and CC .5. Im not sure what im doing wrong if anything. Im at a loss. Have not had this issue till now. Im almost out of powder but I ordered some yesterday. I get the sample from the same spot each time. i also use the quick stir. Dumb question but I fill to the 10 spot and then drop the stir in. Is that the correct way since it raises the level a but?
    Richard320's Avatar
    Jan 2010
    19,075
    Yes, the testing procedure is correct. Measure, then stirbar.
    Doublecheck the poolcalculator. Make sure the gallons didn't go back to default and/or you mistakenly selected 6% instead of 8.25% for the chlorine. That would mess you up.
    Mar 2013
    Waco,Tx
    43
    Yea I double checked and its correct. Im at a loss and not sure what to do next
    Richard320's Avatar
    Jan 2010
    19,075
    Wait.
    FC will come down on its own, and fairly rapidly, since it's a percentage, not a fixed PPM.
    When you do the FAS-DPD test, don't skimp on the powder. Two scoops may be too much, but there should be one or two undissolved granules in the pink water begore you start counting drops. They'll disappear. Too little powder can give a false low reading.
    Mar 2013
    Waco,Tx
    43
    Ok thank you. im gonna check again tonight
    Mar 2013
    Waco,Tx
    43
    Just checked it tonight
    FC 14
    CC 1
    Is the drop too rapid from the readings this morning? The water is still pretty clear. I just cant seem to get accurate readings of late.
    Richard320's Avatar
    Jan 2010
    19,075
    FC 14
    CC 1
    You lose chlorine faster at higher concentrations. And the presence of CC tells us that something is still growing in there, which also uses up FC. Keep at it. If it's clear, you're getting close.
    Mar 2013
    Waco,Tx
    43
    Checked this morning before work
    FC 10
    CC .5
    When I checked last night it was about 6pm and still had several hours of direct sun.
    Richard320's Avatar
    Jan 2010
    19,075
    FC 10
    CC .5
    Try the OCLT again. How's it looking? Does it sparkle yet?
    Mar 2013
    Waco,Tx
    43
    the water is pretty clear. It was only a lil cloudy to begin with.. I have to wait for more of the powder to come in tomorrow.
