Hi,
I went to the pool store to get the water tested assuming that they will do a more accurate readings. Shocked to see the inconsistency of the results
Yesterday readings:
CYA 23
TC 2.6
FC 2.6
PH 8.3
TA 82
Adj. TA 75
CH 99
Salt 3200
TDS 4700
Temp 70
Today readings:
CYA 80
TC 3.1
FC 2.7
PH 8.1
TA 81
Adj. TA 57
CH 80
Salt 3200
TDS 5000
Temp 78
- Yesterday I added 4 pounds of baking soda to raise the alkalinity and no other chemicals
- It rained last night
Questions:
1. I cannot understand how CYA can jump from 23 to 80 in one day without adding any more
2. Adjusted TA went down from 75 to 57 -- AFTER adding the baking soda!
3. CH went down from 99 to 80 in one day!
Are these readings possible or the pool store tests are completely inaccurate?
Is it possible that I messed up taking the sample?
Here is a history of the readings this season
5/1 5/2 5/4 5/10 6/2 6/3
CYA 0 0 51 41 23 80
TC 0.8 0.4 0.3 4.7 2.6 3.1
FC 0 0.4 0.3 3.7 2.6 2.7
pH 7.7 7.2 6.8 7.1 8.3 8.1
TA 71 70 44 73 82 81
AdjTA71 70 27 61 75 57
CH 107 98 115 163 99 80
Any recommendations?
(SWG vinyl pool, 35k gals, no heater)
Yesterday readings:
CYA 23
TC 2.6
FC 2.6
PH 8.3
TA 82
Adj. TA 75
CH 99
Salt 3200
TDS 4700
Temp 70
Today readings:
CYA 80
TC 3.1
FC 2.7
PH 8.1
TA 81
Adj. TA 57
CH 80
Salt 3200
TDS 5000
Temp 78
Questions:
CYA 0 0 51 41 23 80
