Results 1 to 10 of 10
Thread: ok time to buy new heater. suggestions, guidelines?
    Jun 2008
    Buffalo/Niagara Falls NY
    30
    Looking online to buy new natural gas heater with I guess an electronic ignition. I had Teledyne Laars 125,000 BTU. How many BTUs should I get, is it determined by piping already there? Bigger, better? Talked to rep at Intheswim. fumbling around. Ease and reliability main issues of course. Then to find someone to install. Had bad experience with last pool service guy. Thanks Teresa
    15x 30 inground oval vinyl lined. 15000gals. Jacuzzi 250lb sand filter. Laars lite natural gas heater. 6 foot slide, underwater light . 3.5 ft. shallow,to 7ft. deepend. TF 100 test kit
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: ok time to buy new heater. suggestions, guidelines?
    It would help to know where your located, and if the old heater seemed to provide enough heat for you.
    Afterall the size of heater needed for your size pool is likely a bit different in Fargo, ND vs Miami, FL
    You can put your location in your profile like most of us have.
    Jun 2008
    30
    oh sorry, I am in sunny Buffalo/Niagara Falls area!! Seemed like old heater would heat about 1 degree an hour.
    38,475
    You are limited in BTUs by the size of your gas line, unless you intend to increase it too. Do you know the length of the run and diameter of the pipe?
    Larger heaters will do the same job in less time ... using basically the same amount of gas.
    Seem to recall a few threads recommending the Raypaks
    Jun 2008
    30
    the diameter of pipe appears to be one inch. Length of run, do you mean from heater to actual pool or from heater to filter? Pardon my stupidity. I am obviously clueless. Thats why TFP is a safe haven!
    38,475
    I mean the gas pipe from the gas meter to the heater ... that determine how much gas can be supplied and limits the size of the heater. If it is over-sized, you may be able to increase the size of the heater if you wanted.
    Jun 2008
    30
    It's about 5 feet from heater to gas meter. I would be willing to go up in size whatever to get more heat quicker,etc. Here in Buffalo we/I just want to go in as much as possible. I can only go in if its at least 80 to 83. Heart condition plus dang i just like it like that!!
    38,475
    That would likely not cost too much if you did have to increase the pipe size ... you may need to get a larger meter as well (free in some places).
    A 400k BTU heater will heat the water about 3 times faster than your 125k BTU heater did.
    You likely need to consult with a local installer to find out if a pipe size increase would be required and the cost.
    Jun 2008
    30
    Thanks for quick replies. Local installer do you mean someone like pool company or anyone else who can do it? i am sorry i am struggling. you have been great. If i order online it seems hard to find local installer because they of course want you to order from them. Besides pool company what other people/professions do this?
    38,475
    Maybe a plumber for the gas and water pipe? And an electrician for the wiring.
    Good luck.
