- Jun 3, 2013
- 10
I recently replaced a stripped gear for a Jandy 2440 Valve Actuator on the return side of our filter. I didn't pay close enough attention to the cam settings though and after everything was put back together, the actuator was not cycling correctly through the valve positions on the Jandy power center (in order, those positions are pool mode, spa mode, spa drain, and spa fill.) The big problem seems to be that we need the actuator to stop at three different positions not just two. Those positions are:
Position #1 is for pool mode: Water returns to both the spa (for the spillover) and the pool.
Position #2 is for spa mode: water returns only to the spa
Position #3 is for spa drain: water returns only to the pool
Position #2 is for spa fill: same as spa mode, water returns only to the spa.
Does anyone have experience setting the cams on a Jandy 2440 (or 2444) so the actuator can stop in three different positions?
Thanks!
Thanks!
