Thread: Pool Heater & Chlorine Usage
    Hi to all:
    Does the temperature of the pool effect the amount of chlorine used, i.e., as the temperature rises with the use of a pool heater does more chlorine get consumed?
    Gary R.
    18 X 32 Oval Inground Gunite Pool 20,000 Gallons Epoxy Painted in 2012
    Tagelus Sand Filter TA 60 D/TA 60-Hayward Super Pumps 1 H.P.
    Ray-Pac Heater 266,000 BTU, KLeen Machine Pool Cleaner
    Solar Cover-Rocky's Pool Cover Reel-Intermatic T104R Timer
    TF-100 Test Kit-PoolSkim Skimmer
    38,295
    Re: Pool Heater & Chlorine Usage
    To some degree yes as algae can grow more easily as the water temperature increases ... although it may not be enough to be noticeable.
