Thread: calcium hardness
    calcium hardness
    I have a 20,000 gal. inground vinyl liner pool. Do I have to worry if my
    calcium hardness level is low? Also, I just opened my pool yesterday and along
    the crease of the liner(where the wall & bottom meet), I have what looks like some rust stains. I shocked the pool and look like everything else is balanced. Any suggestions what to do?
    Dave
    Pool: 20k gallons, converting to SWG from Baqua, sand filter, vinyl liner.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,988
    Re: calcium hardness
    Low Calcium = no problem.
    Rust stains can be lifted by covering them with vitamin C tablets. Organic stains, from rotting leaves and such, will bleach out eventually.
    38,275
    No worry about low CH.
    Try crushing up a vitamin C tablet and putting it on the stain to see if it goes away.
    Why did you "shock" the pool? Did you follow the Shocking Your Pool PROCESS?
