Results 1 to 7 of 7
Thread: pool test results. Any suggestions
    buckhunter835's Avatar
    May 2013
    Seirra Foothills, California
    15
    pool is crystal clear. should i try to adjust anything.
    June 3, 2013, 07:50 am
    FC 4.0
    CC 0
    PH 7.8
    TA 210
    CH 240
    CYA 60
    SALT no test
    ACID no test
    IRON no test
    TEMP 70*
    Thanks for the help
    30,000 gallon pool/spa/infinity edge/sun deck, 9 1/2 FT. Deep, 25' x 47', Wet Edge Prism Matrix Eclipse, Pentair Easytouch 8SC-IC40, 2- 3hp Intelliflo Variable pumps, 3- Intellibrite 5g led lights, 1- Intellibrite 5g led spa light, 1- Intellibrite 5g led spa light Infinity trough, 2- Jandy pro Led Lights for Sun deck, Pentair TR140 Sand filter, Screen Logic Bundle, SR400HD MAX-E-THERM HEATER 400k BTU Cupro Nickle, 2 HP Blower,
    22,553
    Re: pool test results. Any suggestions
    Where did you get those test results?
    I'd probably bring the pH down to about 7ish.
    38,475
    Quote Originally Posted by buckhunter835
    Depends if you trust the pool store testing ... we generally do not, and put much more faith into performing our own reliable and repeatable testing using one of the recommended test kits.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    Lower pH a bit, because with the SWG and high TA, it will soon rise.
    http://www.poolcalculator.com/ can help. Scroll to the bottom of the table where it says suggested goal levels and enter troublefree, SWG, and vinyl.
    May 2013
    15
    thank you for the help,
    sorry for late reply got called into work.
    I did the test, I purchased the testing kit from this site tl100?
    I will lower ph using pool calculator.
    what is the proper way to use m.a. pump running or off?
    May 2012
    North of Charlotte, NC
    312
    Pump running and poor slowly into deep end in front of return jet....I hold my breath from the fumes most of the time and wear spoggles while pouring....helps a lot....
    And with a CYA of 60 pool calc says FC should be between 5-9ppm so ya may wanna bring it up a bit....
    24,000 Gallon Vinyl Grecian IG,Triton2 Sand Filter / Pentair Super Flo 1 HP Dual Speed Pump ,
    Stenner Peristaltic Pump Injection w/15 gal drum,Stubbed up supply/return for future solar panels :)
    TF100 Rocks !! Pool School....
    May 2013
    15
    OK THANK YOU. I WILL GO DO IT NOW
