Thread: Pool Light Question?
    May 2013
    Barto, PA
    10
    I have a recently purchased home with a cement pool. There are two lights in the pool, neither are working. I have what appears to be two relay boxes next to the outdoor sealed switch which I assume means these are low voltage lights. Before I start my diagnostic routine I though I would pull both lights from their niche's and work my way back to see where the problem is. Here's my question. I just went into the pool Saturday to inspect the lights. Neither appear to have a retaining screw on the bezel for removal. Where there lights at one time that were just pushed into the niche? There's a lot of paint on these but I still don't see where there was a screw. I thought I would ask before I start prying.
    35k gal, IG plaster, 1.5 Pentair WhisperFlo
    Sta-Rite System3 300 sqft filter w/3 cartridge conversion
    Dolphin Z5 Robot, Hasa Liquidator
    Vintage Master Pool 18'x45'
    30,431
    Re: Pool Light Question?
    The retaining screw is usually quite small and located right at the top (TDC)
    I don't know if they were ever made without the retaining screw.
    I had the same problem, and determined the pool contractor had installed a different brand of wet niche and light fixture. Therefore, the screw in the light fixture does not match up with the niche. Could there be an electrical bonding issue with no mounting screw?
    May 2013
    Allen, TX
    110
    Make sure the GFCI protecting the lights isn't tripped. I went through the hassle of replacing the bulb until I figured out it was simply the GFCI needing to be reset.
    ~15K gal, IG gunite with new Wetedge Satin Matrix Pebble Finish installed mid 04/14, 1 HP Pentair Challanger pump, Sta-rite System 3 300 sqft cartridge filter, G3 cleaner
