Thread: Pool opening. All going well. Chemistry right on but problem
    Feb 2012
    East Hampton, NY USA
    26
    with vacuuming. I got most of the leaves out of the pool with a bag net and bought one of those caps that go over the strainer basket for the vac hose. It all worked great vacuuming the other day but today the cap just kept popping off.
    I had blocked off the other skimmer and shut off the main drain valve. Got kind of frustrating. Should I just pull the strainer basket and plug the vac hose directly into the bottom of the skimmer ? Then clean out the strainer basket in the pump when finished ?
    APSP Certified Service Technician
    Re: Pool opening. All going well. Chemistry right on but pro
    It's odd that it worked one day and not the next. The only explanation that comes to mind is that if your suction has decreased a bit due to your filter needing cleaning, it might affect the cap staying in place. Has your psi gone up appreciably on your pressure gauge? If so maybe you need to backwash. Also, check the strainer basket in the pump. If this is full of stuff it can affect the suction. If neither of those solve the problem, I guess it would be okay to vacuum without the skimmer basket in place. Or, I guess you could vacuum to waste.
    Tom
    In gound vinyl L, ~41,000 gallons, Pentair Clean and Clear Plus 420 cartridge filtter, Pentair 2 speed WhisperFlo pump
    Feb 2012
    26
    Thanks Tom for your reply. Psi was at 24 so it seems good. Strainer basket in the pump was clean from the previous vacuuming I gave it about 4 days ago. I'll give it a shot again tomorrow without the basket and the cover adaptor.
    Feb 2012
    26
    Feel like a real dope. Problem was I had the hose attached backwards. I had the swivel end on the cover plate in the skimmer. Worked like a charm today. Pool is super clean now. I'm a little bit of a greenhorn but learning quickly. I hope my mistake will help others from making the same in the future. Best to all.
    Simple Pool Pro Rocks ! Yeah Baby !!!!
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    LOL! I made that very same mistake last year....there should be a label on the hose (vac side/suction side) Glad you figured it out.... and Welcome!
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Feb 2012
    26
    Quote Originally Posted by harleysilo
    Thank you sir!
