Thread: Cyanuric Acid
    Cyanuric Acid
    I work for a condominium complex which has a pool. We have a flow through chlorination system and use 4 inch sticks. My question is this. Is there a pool chemical manufaturer that makes chlorine sticks without stabilizer? My pool has been open for only a week. It was not drained at the the start of the season and while my initial CYA test, a week ago, was 70ppm, it is already approaching 100ppm. While I realize I have to dump some water to lower the CYA it seems so foolish (not to mention wasteful and expensive) to have to keep repeating this again and again throughout the season. Can anyone help me find a non-stablized chlorine stick source?
    30,405
    Re: Cyanuric Acid
    Sorry, Joe, they are not made. You either need to drain off some water from time to time to reduce your CYA or go to a liquid source of chlorine.
    No P in my ool's Avatar
    Jun 2007
    Logan IA
    219
    Re: Cyanuric Acid
    When I serviced pools that used sticks or pucks we back washed them for fifteen minutes twice a week to manage the cya.
    21' Leslies Beachland Ag Pool, 10,000 gallons, professionally installed (best money I ever spent) Hayward 16" sand filter w/Pentair two speed pump Fafco 4x20 solar heater,Aqua Trol RJ. Borates added. Hard plumbed.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Cyanuric Acid
    Quote Originally Posted by No P in my ool
    Yeah, that could work, but somebody's gotta' pay for all that water, too.
    You're done SLAMing when:
    Jun 2007
    Logan IA
    219
    Re: Cyanuric Acid
    Quote Originally Posted by Butterfly
    That's the price you pay for using stabilized chlorine.
