Thread: DE & leaf debri in pool
    I have a Pentair Plus DE filter, and have a slight amount of DE and debris still coming thru the returns and also clogging up my screen to the Polaris vacuum. Have checked the grids for tears, nothing, checked the regulator and seems fine, pulled the multiport valve apart and checked gasket, all seem fine......I'm at a loss as to why this is happening. Any ideas
    Vinyl 18x36 IG with deep end, 25,000 gallons, 1 1/2HP Pentair Pinnacle pump, Pac-Fab Triton II TR60 325# sand filter, Aquabot low voltage vacuum. Pool installed in 1995, on its' second liner
    Have been using BBB method for years
    22,548
    Re: DE & leaf debri in pool
    The most common reason for DE and debris to be returned to the pool is either torn or improperly installed grids Did you make sure the grids were seated correctly? Did you check really closely for tears? A small tear can return a bunch of stuff to the pool.
    kcindc's Avatar
    Sep 2011
    Fairfax, VA
    1,274
    Last year I had a small crack in the manifold of my DE filter. The crack was barely noticeble to the naked eye, but once the filter is under pressure, it pushed out all of the DE through the little tiny crack in a matter of minutes. My grids were pretty old, so I opted to replace the entire assembly.
    I wouldn't run your polaris because my jets became clogged from the filter leak and I had to get the Polari repaired, too.
    Karen
    33K IG w spa plaster, Pentair 1HP Whisperflo, DE Filter, SWG CircuPool RJ-60, Dolphin Triton Plus, Raypak Dig 336K BTU, TF-100.
    Pool Math Chlorine / CYA Chart SLAM - Shock Level And Maintain
    2017 replaster/retile
    Jun 2013
    Baton Rouge, LA
    10
    ditto. absolutely tiny crack in manifold will spit out all of your DE in a matter of a half-day.
    17k gal (16x32 ig), vinyl, Hayward DE filter, Taylor K-2006, south Louisiana
