Thread: Repairing broken wheel on Polaris 280
    May 2013
    New Jersey
    64
    I don't know about any of you, but this wheel has broken before.
    I ordered a new one, which are only about $13.00. But it takes me a few days to get a new one, which are a few days I wouldn't have a vacuum working. Also, I when I have the new one, I will now still have a spare.
    I used this product to FUSE, or "weld" the plastic together. It is called "Tenax 7R". Available in hobby stores. (I have NO affiliation with this company. Just good stuff I've used)
    Just remove one Phillips head screw to remove the cover, and and two more to remove the wheel.
    Then use a Q-tip to lightly coat all the mating surfaces. Don't go crazy, as it will just take a while to "dry". You just want both sides tacky to use HEAVY hand pressure to fuse them back together.
    While holding it TIGHTLY together, I rub the joint with the compound to make it look finished, and a complete-through-plastic-weld.
    This Tenax 7r will work on any part of that white plastic.
    WAIT 8 HOURS...
    Ready to re-install!
    Bernie
    Bernie
    20,000 Gallon (16 x 32), IN ground, Vinyl Pool
    Hayward Single Speed 1-1/5 Hp Pump - 3/4 HP "Booster" (?) Polaris 280 Vacuum
    48 Sq Ft, 96 GPM, Diatomaceous Earth Filter
    Pool is approximately 15+ years old- Newer than 1985
    Hayward 300,000 BTU H300MV Heater (Milli-Volt UGH!!)
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Re: Repairing broken wheel on Polaris 280
    So how would you compare it's holding properties to say JB Weld? I have to fix a LOT of broken plastic toys for the kids, JB works okay, but eventually fails. Plus side is it dries quick. Thoughts?
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    May 2013
    New Jersey
    64
    Quote Originally Posted by harleysilo
    I love Epoxies, which work on lots of things- and joining dis-similar materials.
    This stuff only works on plastic, and as far as I know, two pieces of the same plastic. It actually disappears- when joined with some pressure, it dissolves and actually becomes one piece of plastic again, like metal weld would. Using JB Weld would be the equivalent of soldering metal
    I haven't tested it on every plastic, but so far quite a few items. I wish I was better at identifying plastics, or I could list them!
    But definitely worth the $3 a bottle I spent- only using a q-tip's worth at a time! And I still see it for $5 a bottle online, right before I rote this. I wanted to make sure it was still sold.
    I can try it in a few other things and let you know!
    Bernie
    Bernie
    May 2013
    New Jersey
    64
    I have to add to this thread, that I am a dork.
    I am sort of new to this house. I am still finding things here and there that I didn't know About. While cleaning out the shed yesterday, I found an old Polaris Letro (?) Pool vacuum, and it has the same wheels and axles as the Polaris 280!
    So now I have four spare axles that Look less likely to break since they look like nylon (?) and are thicker. I believe the new white plastic ones were meant to break off to save something else from breaking if it got jammed in there.
    I was also able to pull a bunch of the stainless steel screws out of it as spares, and put most of the remainder in the recycling bin instead of garbage!
    Bernie
    Bernie
    May 2013
    California
    46
    I use PVC POOL-TITE GLUE - it's that blue glue that you use when you fix your sprinklers or pool plumbing. I let it dry for 24 hours - it goes on good and sticks fast in hot weather. I have two Polaris 180 cleaners being held together with this stuff. It is also very long lasting in the water.
