last evening i found a thread from chemgeek i believe and it told how to figure out how much borax to use per 1000 gals for the life of me i cant seem to find it again any suggestions?
The main reason that they aren't included is because they are an optional thing... the test kits are everything you NEED to maintain a pool...;31377 said:This is, in fact, pretty much the same test as the Proteam titration test. Meq/l can be converted into ppm with that much trouble if you understand some basic chemistry. Once again I say that for home use the LaMotte Borate test strips are the easiest way to go for reults that are certainly accurate enough for borates!
Dave,
Ever consider these as an option or add on to the TF100 kit?
