Results 1 to 16 of 16
Thread: stamped concrete around pool
    Hello. I am so glad I found this forum. We are getting ready to build soon and I have tried to search the forum to find as many answers as possible. Somewhere I saw a pool that used stamped concrete around the pool and as the coping. The person mentioned that the "rock" look stamped concrete was what many resort pools use. I am wondering if any of you have this (and if so would you share a picture). Also, how hot does it get? I really appreciate the input.
    30k Gallon in-ground, Vinyl, Loop-Loc cover, Hayward Super Pump, Hayward s-200 sand filter, Dolphin supreme m5, TF100 Test Kit, Speed Stir
    May 2013
    North East Ohio
    959
    Re: stamped concrete around pool
    I am in the middle of a build and will be getting stamped concrete...looked at other jobs the builder did and looks awesome. As for heat, the LIGHTER the better, as DARK concrete will be a bit hotter, but no worse than any other decking material.
    For our coping though, we did specialty pavers just to give it a bit of contrast. I have no pics, other than the PB website, which I am not sure I am allowed to post. If someone (official) tells me I can, I will post up the link.
    Good Luck!
    14,750 GAL IG Fiberglass (16 x 33) NE Ohio || Jandy 1HP 2 speed Pump || Waterco MultiCyclone 16 Centrifugal pre-filter (removed due to not working with sand filter) || 30" 575 Lb. Sand Filter || AquaCal 140K BTU Heat Pump || Solar Cover || Inter-fab Adrenaline Slide || GLI Monsoon Solar Cover Reel || K-2006C Test Kit || BBB with Liquid Chlorine Stenner Injection || Rayner Mighty Mesh Winter Cover
    I really hope they say yes! I would love to see ideas.
    Jul 2009
    Fort Wayne, IN
    392
    ours is stamped, but I'm not sure it would be called the 'rock' look. It is more of a slate/granite look. We love it. It gets warm when it's dry, but there is almost always water on it from splashing. when I'm vacuuming or maintaing the pool and it gets warm, I just dip my feet in the pool. So many people warned us about how slick it gets. Ours is not slick at all. As far as I know, then didn't put anything in it to make it non-slick. The stamp they used creates a non slip surface all by itself.
    [/URL]
    Theresa and/or Gary
    Complete DIY: 20x40' rectangle. Resin walls, vinyl lined. 33000 gallons. Full width steps. 8' deep. Diving board, slide. Hayward pro series super pump, sand filter. Raypack 336K BTU heater. Main drain, 2 skimmers, 3 returns, 2 amerilite lights with quick change lens Aquamatic auto cover and a partridge in a pear tree.
    Breaking our backs in the hopes that one of our six kids will care for us when we are old ;)
    Thank you, I had not thought about it being slippery. Very cool slide! I wish I could talk my husband into one.
    Stamped here. With something called "sure step" over it. Slick as GLASS! going to have to do something. Not as bad for me as I am used to it and a lot less likely to be running than most of the pool's users. We had an 11 year old party last Friday and a 13 year old party on Saturday, and that was the first thing I addressed to each group before they even got wet.
    Yes, hot also, but our pool gets FULL sun from 9:30 until almost 7 right now. Have been uncovered and swimming since March 30. Temp is 86 without even using the solar heater right now. It's our first summer with it and we couldn't wait any longer.
    Congratulations on getting one, and hope it goes well for you.
    We just came from a party last weekend where they had stamped concrete. My husband counted 20 kids that fell and they were not running. Very slippery.
    16 x 32 rectangular, 21K,IGvinyl, 1.5HP Sand Dollar Pentair superflo high performance pump, Pentair IC20 intellichlor chlorine generator, LED intellibrite 5g light, Raypak Heater 335,000 BTU
    Just to say, I don't think mine is slick because it is stamped. I think it is slick because of the sealer used.
    Apr 2013
    Central Massachusetts
    174
    Quote Originally Posted by 8corneflakes
    Do you know what sealant was used on your deck? Oil based seems more slick than water based. I like the look of the oil based, but will probably go with water based for the extra grip.
    26,000 gal 18x36' IG Vinyl Pool - Hayward S244T Sand filter - Hayward Tri-star 2-speed 1.5HP pump - Goldline Aqua Plus SWCG and Controller with Tcell-15 - Aquacomfort 125K BTU Heatpump - Hayward Color Comfort 4.0 LED - Zodiac MX8 suction cleaner - TF100 test kit
    My Build thread
    May 2013
    North East Ohio
    959
    My PB insisted my stamped would be no slicker than normal concrete, pavers, etc. So hopefully I will find out soon that he is correct. My pour is scheduled for sometime in the next two weeks.
    I just had mine done using what's called "textured Stone" finish. The colors used were silver base with charcoal release. The "brand" was Stampcrete.
    The sealant that was put on uses some kind of fine grit mixed in with it so it is supposedly no more slippery than ordinary brushed concrete. Not all deck companies I spoke to used it but the guy I used said he uses it on every deck he pours. From my limited time on it, it seems to be non-slippery but we shall see this weekend when my kids are running around it.
    No clue on "hot" yet but my cement guy swears it gets no hotter than standard brushed concrete.
    The finished color on mine now that it's dried is lighter than what you see in these pics. The last pic shows a few areas that they came back to touch up which appear darker than the rest of the deck which has had time to cure.
    2012 (late install) 20x40 inground Oasis steel pool with vinyl liner. Pentair DE Filter with Whisper Flow 1HP pump and Pentair 400K BTU heater.
    2016 Marquis Promise Spa (2 pump model)
    Apr 2013
    DFW, TX
    72
    I thought I'd mention SunDeck. Its a spary on product over concrete and is supposed to be textured (slip resistant) as well as cooler than other materials.
    It also has the ability to be applied in various patterns and colors to mimic stone or other products.
    sdspencer's Avatar
    Apr 2013
    Temecula, CA
    42
    We have cantilever coping that was poured in place before the deck. We were supposed to have the coping broom finished and the deck stamped for a slight contrast since they're both gray, but the guys accidentally stamped the coping so we decided to broom finish the deck instead. Not sure what that's going to look like when it's said and done, but it's too late to go back now.
    The deck was poured 2 days ago and is still drying in this picture:
    Approx. 16k gal (16.5' x 30.5') Freeform, Salt Water, Stonescapes Tahoe Blue Mini Pebble, Intelliflo Variable Speed Pump, Hayward Shark Vac Cleaning Robot
    We had "Stampcrete" stamped concrete (installed by John Sayer from Blairstown, NJ) used for our front walk, front stoop and back patio. What a debacle. Within 1 year the concrete pour on the back patio and the front stoop was scaling up - huge pits. No issues with the front walk which came from the same pour as the front stoops. Installer came back and said it was because I used salt - not true. I kept calling him and he came back a second time about year and a half after the job had been completed. He agreed there was an issue with the concrete but didn't want to take core samples for testing, then he stopped taking calls and never showed up.
    I spoke to a lawyer, it would cost me about 7k dollars to sue him for 7.2k dollars to repair the work so we're in limbo right now.
    The pastor at our local church also had stamped concrete used for the public area between the church and the rectory - they're having the same kind of scaling issue.
    Stamped concrete looks great if you don't have any issues.
    21' AG (~11,000 gallons)
    Hayward S180T sand filter (35 gpm)
    Hayward Power-Flow SP1510 pump
    Hmm...I was totally sold on standard brushed concrete until landscapers/pool builder/neighbors all said that no one does that anymore and everyone does stamped. Kind of regretting that right now and its only been a few days....LOL!!!
    Jun 2013
    Southwick, MA
    211
    Any Concrete is all about the prep work, it has to be prepped correctly.
    I have stamped on my Front Porch, Walk Way, and Back Patio. They all look great after 3 years, but they are slippery. I am told there is a finish you cna put on it to make it have more grip, but I never tried it.
    24X44 IG Vinyl Custom Shaped Pool, Starite S7M400 Cartridge Filter, Starite Sumpermax VS Pump, built July 2015, TF-100 Test Kit, Pentair Intellichlor IC40 SWG, NG Starite SR400 Heater, Easytouch with Screen Logic, Magicstream Laminars, Bullfrog A7 Spa
