Thread: Step Jet Air Connection
    Feb 2012
    Maryland
    400
    I have the CMP Step Jet kit im installing. The issue im having is the air control is not deep enough to go through my pavers and CMP says they do not make on longer.
    1. Can I eliminate the air control and block the air port on the jet assy?
    2. Will it then work just like a return?
    3. Would there be any issues if I were to use the air control but extend it?
    DIY 18x36 IG Vinyl Rectangle with 2 foot radius; Steel Walls. 8' steps w/t 2 step jets; 2 MD, 1 Skimmer, 2 returns; Hayward Pro Series 24 Inch 300# Sand Pool ; Hayward color logic 4.0 LED light; 2" PVC pipe 4 Jandy Valves, Hayward PL-P-4, SWCG
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: Step Jet Air Connection
    1 yes
    2 yes
    3 I don't believe so.
    Mark
