Thread: Skimmer Overflow built in?
    May 2012
    North of Charlotte, NC
    312
    I remember hearing sometime ago that most if not all IG pools skimmers have a sort of built in overflow at the very top ring of the skimmer assembly that basically just allows excess water to flow into the gravel bed surrounding the outside area around the skimmer therefore allowing the water level to not ever reach the liner track at the very top??
    Any truth to this in anyway? Or do most folks not count on that (if true) when the rain water brings the level up high and just go ahead and pump it down to normal levels??
    24,000 Gallon Vinyl Grecian IG,Triton2 Sand Filter / Pentair Super Flo 1 HP Dual Speed Pump ,
    Stenner Peristaltic Pump Injection w/15 gal drum,Stubbed up supply/return for future solar panels :)
    TF100 Rocks !! Pool School....
    38,268
    Re: Skimmer Overflow built in?
    The 2 pool I have had, did not have any built-in overflow. Not sure it is typical or not ... appears not where I am located.
    May 2012
    312
    Humm...I have a local builder coming by this week to give a estimate on a liner replacement and some other things, I'll have to see what his past experience has been in this area....
    Apr 2012
    Southeast Louisiana
    174
    The skimmers I've seen include an overflow as you describe, but it's something that needs to be specifically plumbed (and a knockout removed from the skimmer body).
    --Michael
    Slidell, Louisiana (near New Orleans) 11,000gal kidney shaped Trilogy fiberglass pool Intelliflo VS Triton TR100 filter Easytouch 4 w/IC20 SWCG Polaris 280
    Jun 2016
    Mechanicsville VA
    1
    I am buying a house that has that type of system. I don't know if it is by design or by accident though.
    vminuke
    18x36 below ground liner saltwater pool
