Thread: London Ontario, Canada.
    May 2013
    London Ontario, Canada 1hr NE of Detroit
    5
    Hi folks.
    First, I like to say thanks, to all that have contributed to this Forum in whatever way they have.
    Second, I've been lurking @ this Forum for @ 3yrs. reading and researching.
    We bought this house 3.5 yrs. ago, and prior to that I never wanted a pool let alone, enjoy one. It just came with the house and was under 2ft of snow.
    I'm a bit of a workaholic. At home I'm always planning and prepping the next 5 projects before finishing the current one. A pool makes me slow down and smell the roses, if u know what I mean. I guess I didn't want the extra work. But I've learned it not that much aside from opening and closing. A beautiful "t" shaped pool with Roman stairs at the top. Top of the "t" is all shallow and the bottom of the "t" is the deep end.
    As a note the previous owner had use a pool additive called "C-Pool Mineral Treatment". It worked very well. I purchased my TF-100 and a Copper Test Kit, the first year with the pool. All has been great. Opening was easier and faster then this first year of committing to BBB. I've dabbled with the BBB that last 3 yrs. but have decided to try a BBB opening.
    The mistake I made when opening a 3 weeks ago(mesh cover) was not maintaining "Shock Level" long enough-till crystal clear. I assumed once passing "OCLT" and CC is 0.5 or lower, all was good. Till I dug deep into the forum. At 35,000 gal. it's taking its time filtering out the dead algae. Currently adding DE to sand filter. It's helping. I'm still maintaining "Shock Level" and have already used 100 litres of 12% chlorine. Hope to got to maintenance level in the me t 2-3 days. We'll have to see how long it takes next spring w/no errors.
    Apologies for being "long in the tooth".....
    Take care,
    Dave.
    35,000 gal. Vinyl Liner I.G. pool @6yrs old.
    Pump: Jacuzzi. 1.5 HP
    Filter: Jacuzzi Laser250 w/6way valve, 350 lb, 8hr turn-over.
    Mesh Lop-Lok Cover
    TF-100 Test Kit - Pool School - Pool Calculator - Chlorine/CYA Chart
    Always use skimmer socks!!! Aquabot Turbo T.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,046
    Re: London Ontario, Canada.
    Welcome, eh?
    Butterfly's Avatar
    South Carolina
    10,045
    Welcome to the forum
    You've have lurked and learned!
    Will you post a pic of your pool for us
    You're done SLAMing when:
    Apr 2013
    Austin,TX
    75
    Welcome to TFP
    Pool IG, 20'x30'x5', 15,000 gals, QuartzScapes NPT Tahoe Blue, Sundek Classic Texture, DE Hayward Pro-grid DE7220 , Pentair erosion auto CH, Main PMP Century 1.5hp , Polaris 280, booster PMP Century 3/4hp, Electronics PNL timer/light Pro Logic Model AQL2-SS-RF w/Remote CNTL
    Feb 2008
    Denton, TX
    5,061
    Welcome to TFP!
