Thread: New Pool Owner Needs Help With Setup (Bars Bending Inward)
    Jun 2013
    BC - Canada
    1
    Hello TFP Community, I just got our very first pool (Polygroup Pro Series Rectangular Pool 22' L x 13' W, 52" H).
    Frist, Problem we had was a few liner holes for the poles at each end of the pool did not fit, we had to cut a slit so that the poles could go into the holes to lock in.
    Second, The pool we found is not level at all, We had about 4inches of water pool up in the corner before water touched the the opposite corner.
    Thrid, The water is about half full and the side bars have really caved in or bending inward, is that normal until its full of water? We are thinking once its full of water the side bar or rim bars will go back to being straight.
    I will take a few pictures to give you a better idea of what I am talking about. The family thinks everything is fine though and is not worried and just wants to fill it up to the 80% mark.
    Thanks TFP,
    WaterBaby
    Above Ground Vinyl 2012
    (22' L x 13' W, 52" H)
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: New Pool Owner Needs Help With Setup (Bars Bending Inwar
    Welcome to tfp, WaterBaby81
    Quote Originally Posted by WaterBaby81
    I would stop filling then drain and re-level, 4 inches is too much imo.
    I am not sure about your particular brand, but this seems to be what happens to this design of pool.
    Post the pictures!
    Casey's Avatar
    SW PA
    10,448
    4" is too far out of level. Please post pictures.
