Thread: Vit C Stain removal process??
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    414
    Could someone direct me to a post or explain how to remove small rust stains on the bottom of a plaster pool.
    Some metal bristles got left on the bottom from wire brushing coping while the mason was doing coping repairs.
    Most are in the shallow end.
    Thanks
    25k 20x40 Gunite w/ integrated Spa & Caribbean Blue Plaster, Curved Bluestone Coping, Deck Jets
    Pentair Easy Touch/Wireless, Sta-Rite Intellipro SRVS Pump, Intellibrite Lights, & Pentair IC40 Cell, Sta-Rite 450sf Cartridge filter
    Heated from Central Boiler - Outdoor Wood Furnace & Triangle Tube Max Heat Exchanger
    ColorQ Pro
    TF-100
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Vit C Stain removal process??
    Here is an article on removing metal stains: Metals in the Water and Metal Stains. Within this article is a link to the Ascorbic Acid treatment process.
    Was editing my post to correct a typo and add one more thing and Butterfly beat me to it: If we're talking about a few isolated spots that are the result of a one-time event like what you describe, rubbing a Vitamin C tablet on the stains should suffice.
    Butterfly's Avatar
    South Carolina
    10,045
    Small stains? You can crush some cheap Vit C tabs in a sock and hold/rub it on the stain.
    You're done SLAMing when:
    blakeusa's Avatar
    Jul 2010
    Ashford, CT
    414
    Thank you.
    Will give it a try this week.
    ColorQ Pro
    TF-100
