Results 1 to 9 of 9
Thread: Is it possible or advisable to add a second skimmer?
    Jun 2012
    NW CT
    77
    We have a 21x43 agp and it came with only 1 skimmer and return. We haven't had it a full year yet but it just seems to me that if we had 2 skimmers at least and maybe just the 1 return we would get much better flow,movement, and filtration. Right now it seems we always have stuff floating on the surface. The pump has been running 24/7 now for 11 days trying to clean the swamp and there is still stuff floating.
    So do you guys think that would help or not?
    If so, does anyone know of a way to do it without dumping all the water to below the skimmer level? If I could do it with all the water in I may do it now, if not then it def would wait till we closed the pool for the season. I did a quick search but have found nothing.
    Thanks
    43x21x54" Sharkline/Wilbar Above Ground with hopper, 26,000 Gal
    Sta-rite 22 in sand filter with Zeosand removed reg pool sand installed, Sta-rite 1.5 hp pump, Poolsmart Climber Robot, TF-100 Test kit, poolskim, hard plumbing with second return added for poolskim, fafco solar heater, Luiquidator
    May 2013
    North East Ohio
    959
    Re: Is it possible or advisable to add a second skimmer?
    Well I am not a super expert, but I see no way to add a new skimmer (assuming your are in the pool wall) unless the water is lowered. I guess you could add a over the wall skimmer, just the plumbing would be fun. Sure more experts will chime in.
    14,750 GAL IG Fiberglass (16 x 33) NE Ohio || Jandy 1HP 2 speed Pump || Waterco MultiCyclone 16 Centrifugal pre-filter (removed due to not working with sand filter) || 30" 575 Lb. Sand Filter || AquaCal 140K BTU Heat Pump || Solar Cover || Inter-fab Adrenaline Slide || GLI Monsoon Solar Cover Reel || K-2006C Test Kit || BBB with Liquid Chlorine Stenner Injection || Rayner Mighty Mesh Winter Cover
    30,421
    I think having as many skimmers as practicable is a good idea with virtually no downside.
    I am not an AG guy so cannot help to determine if it is a doable idea.
    Taterfink's Avatar
    Apr 2012
    NE Florida
    536
    Many of us have replaced our over the wall skimmers with standard thru the wall skimmers without draining the pools. You can do a search in search window at the bottom of the page for some of our stories. I've not yet heard of any one installing a second one tho. The experts on here would be more apt to be able to answer that.
    EDIT NOTE: Sorry, I didn't read the OP completely. Didn't realize this was a metal side pool. OOPS! Never mind. . .
    Angie M.
    AG, 26' x 52" Intex Ultra Frame, vinyl, 14667 gal. And LOVING it!!! Hayward S15922S 1HP, 2SP pump and Hayward S220T Sand Filter. Hard plumbed with PVC, added second return, intex SWG, Hydro Pool widemouth skimmer. Set up in May 2012!
    N.E. Florida. TF100 - Best investment EVER! (Well, for the pool anyway)
    Jun 2012
    NW CT
    77
    I have done a few searches ow and have not found anything on adding a skimmer or installing one with the pool full of water for a regular steel wall agp. I have found tons of stuff on doing it with intex pools.
    With a steel wall pool I'm just wondering if the same process might work as the intex and if someone else has already been the Guine pig? If you drilled the 4 corner holes and then sandwiched the inside plate and a gasket then a gasket on the outside then the skimmer itself together with the 4 screws you could then drill the rest of the holes and then use something to cut the steel wall from the inside. Idk? Half of it will be underwater so the only thing I can think of to cut the steel wall is a utility knife. The more I think about it the more it doesn't seem possible without draining the pool below the skimmer to do it. Any other suggestions or threads you guys could steer me towards?
    May 2013
    North East Ohio
    959
    So I really think it is nearly impossible to do it right without draining a bit - surely if it were an emergency there would be a way to do something, but the cost to drain/refill a few thousand gallons to do it right seems the way to go.
    Taterfink's Avatar
    Apr 2012
    NE Florida
    536
    Hacksaw? or just the blade? or Keyhole saw? (can opener? )
    Angie M.
    Feb 2013
    Yukon, Oklahoma
    220
    Before adding another skimmer, do you have alot of **** that normally drops in the pool from trees regularly? If so, then you might be a good candidate for another skimmer, but what worries me is that I feel you are saying your filtration setup isn't really doing what you expect it to.
    May I suggest before you go crazy lowering water, cutting up the pool to add another skimmer that you look for a new return jet that has a venturi effect. If I can find the link later today I will come back here and add the exact one I got for my pool. Time for honestly here.....once I did that to my "little" 14' pool, I almost felt I had to much water movement....it wasn't a whirlpool, but you could easily see the water going around the pool. I will see if I can find those returns....they just screwed into the old Hayward return fitting. You may not have a skimmer problem but a water movement problem instead, two skimmers may help but if the water isn't being forced around the pool infront of the skimmer, how is it supposed to suck the **** out of the water?
    Bob E.
    Feb 2013
    Yukon, Oklahoma
    220
    Do a web search for Infusion Pool Products, then hit the "products" page, that will lead you to several variations of the return I used this year. Like I said, BIG difference on the water movement....and don't do what I did. I dremeled out jet just a bit figuring that the opening was just to small....nope, it's not to small, it's just right. Opening it up caused almost to much flow in my little pool.
    Bob E.
