Results 1 to 12 of 12
Thread: Intex Ultra Frame, 2650gph salt system problem
    Jun 2013
    New Jersey
    8
    I just set up my Intex Ultra Frame 16 x 32 with a 2650 sand filter pump with a salt system. I added the salt and did the set up by the book. My salt is perfect at about 3000 ppm but the high salt buzzer keeps coming on. I set the pump and start the cycle and a minute in it starts beeping and starts gives the code for high salt. Anybody have this problem?
    Southern New Jersey
    14,000 Gallon 15'x32'x52" Ultra Frame
    Model CS20110
    Intex 2650 gph pump and sand filter
    Intex salt water system
    Re: Intex Ultra Frame, 2650gph salt system problem
    Have you tried turning it off and back on? Sometimes I have had erratic readings and simply turning it off/unplugging it and turning back on has corrected the problem. That is about as far as my "expertise" goes. There are a lot of people on this forum who ARE experts! Hope it helps!
    16x32 in-ground vinyl-lined pool
    Hayward 1.5 hp 2 speed pump
    Hayward 24" Pro-Series High rate sand filter
    Pentair Intellichlor IC-40 SWG, Pentair multi-color LED light.
    TF-100 Test Kit (the best test kit EVER!!!! If you don't have one, get one NOW!)
    Jun 2013
    New Jersey
    8
    Thanks I will try it.
    Southern New Jersey
    Model CS20110
    Jun 2013
    New Jersey
    8
    Thanks but that didn't work. Any one else have any Ideas?
    Southern New Jersey
    Model CS20110
    Jun 2013
    Fallsburg, NY
    258
    Have you tested the water? What are you using to test the salt levels? Give us your full test numbers and maybe we can help.
    8638 gallon 20'x52" Intex ultra frame round AG. 2650 gph Intex Sand Filter. Intex krystal Klear SWG. (newer model that includes copper ion generation) Hayward 1091LX skimmer, Kreepy Krauly lil shark. Taylor K-2006 w/speed stir and sample sizer. New this year, Intex PureSpa - dichlor-> bleach method for sanitizing.
    New pool, 16'x36' (approx 18000 gal) in ground pool, Haywood DE filter
    Jun 2013
    New Jersey
    8
    I have been using Leslie's salt test strips. They are reading 2500 ppm. I have also used Aguacheck which are reading 2620 ppm. I have also had water checked by two pool companies both read 2600 ppm. I know it is not "salt problem" It is something in the pump that is making it read high salt. I called Intex and explained the problem they sent me a new $219 pump for free. But I got the same results. I didn't know if there is a way to adjust the setting on the the inside of the pump? So now Intex want me to send one pump back on my dime that is not going to happen. The other readings in the pool are with in range. If I hook up a battery charger to the chlorine maker it self it works but I cant use the timer it is a pain in the butt. Thanks
    Southern New Jersey
    Model CS20110
    Jun 2013
    New Jersey
    8
    Has anyone had a look at the wiring in the pump housing? What reads the level of salt in the water? And is there a way to disconnect the salt meter?
    Southern New Jersey
    Model CS20110
    Jun 2013
    New Jersey
    8
    Where in the pump is the salt measured? Is it at the electrodes where the chlorine is made or is at the copper element?
    Southern New Jersey
    Model CS20110
    Jun 2013
    New Jersey
    8
    Does anybody have a problem like this?
    Southern New Jersey
    Model CS20110
    Feb 2013
    Yukon, Oklahoma
    220
    I kind of had the other problem of being low when it was right in the middle. Once I found the salt was eating my electric pool heater I dumped the salt for BBB and honestly have the best pool ever. I know it seems to late for you but the intex stuff will give you two to three years at best before you will be replacing something. Do what you have to now, but in the future I seriously recommend separate pump and SWG if you go that way and better yet....BBB.
    Other than sticking a running hose in the pump intake to fake the pump out that you have less salt than you do, I feel a partial drain and refill is in you future. Or find some bleach and use BBB for the rest of the season.....
    Bob E
    Jun 2013
    New Jersey
    8
    Ok Safetybob you got me what is a BBB Pool? Already been there and done the pool draining.
    Southern New Jersey
    Model CS20110
    May 2013
    Janesville WI
    74
    got the intex salt water system on my pool. Only had low salt error when my electrodes had massive amounts of calcium deposits on them. Unhooked the Swg put the end caps on and filled with vinegar. Wait a couple hours for the vinegar to work its magic and took hose out and sprayed out everything. Hooked it back up and the error would go away. If you have never run the swg before then I wouldn't have a clue what is triggering the error code...
    Intex 18x48/2650 Sand/56601E SWG
