Results 1 to 15 of 15
Thread: Fist Intex pool, just a question?
    Jun 2013
    Massachusetts
    8
    This is the first time we have bought a intex pool, it's only about 3Feet deep. The filtration system is a 637R. Sorry if my questions seems dumb, but how long am I suppose to run the filtration system especially for the first time? Thank you in advance!
    Maria
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Fist Intex pool, just a question?
    The right answer is long enough to keep the water clean enough for your liking. But if we knew the size of your pool, we could suggest a starting point.
    What size intex pool do you have?
    Jun 2013
    Massachusetts
    8
    Thank you for your quick response. It's only a 10x30. I researched it, and what I came up with was 4-6hrs, but now since it's raining over here, should I let it run longer before the next use of the pool? Like I said this is my first time having a pool with a pump and chemicals. Thank you again The actual model number is 637r.
    Maria
    Vette's Avatar
    Jul 2012
    Ohio
    404
    Rain actually shouldn't hurt the water too bad, just make sure you always keep enough Chlorine in it.
    11,700 gallon 21' round 54" deep all-resin AGP - June 2012
    Waterway 1HP 2-speed pump / 100 sq ft cartridge filter
    Hayward 150,000btu Natural Gas heater
    I use and recommend the TF-100 for testing
    Jun 2013
    Massachusetts
    8
    I put a huge chlorine puck in it last night, I had to cut it up so it would fit in the tiny container that I bought for the pool, I assume that I will have to redo the chlorine once the weather gets better or do I have to keep constantly putting it in until the rain stops?
    Maria
    Vette's Avatar
    Jul 2012
    Ohio
    404
    Are you planning on using Trichlor pucks to chlorinate?
    Jun 2013
    Massachusetts
    8
    Yes, I bought a little tub of them last night? Do you suggest something else?
    Maria
    Jul 2012
    SE Minnesota
    137
    Yes, read pool school, there's a button in the top right of every web page here.
    Intex Ultra Frame 26'x52"
    Intex 2,500 gal/hr pump with Unicel cartridge filter.
    Jun 2013
    Massachusetts
    8
    Thank you, I will take a look. I appreciate all the help
    Maria
    Jun 2013
    Massachusetts
    8
    I'm using the stick to dip, I hate it. What do you suggest I buy? Also, I can't seem to get the pools chemistry to balance at all, it could be the **** sticks that Im using, but the readings are all over the place. UGH
    Maria
    38,303
    Test strips are worthless. See the link in my signature for the test kits we recommend ... the FAS-DPD chlorine test is the key.
    Jun 2013
    Massachusetts
    8
    Thank you, but those test cost more than my sons pool...lol. I know that Ocean State has a test kit like that for $14.00, I'll try that, I know it's probably not going to give me the best result because of the price, but, I can't afford 70-90 bucks just for a 10x30 pool that cost $45.00..lol Although I would save on the water bill, I don't want to keep dumping out the water either. UGHHH
    Maria
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    If you don't want to spend much money, and since your pool is very small in volume, I would look at getting a 2-way drop based test. Most stores have them for under 10 bucks. It has a drop based Total chlorine test and the ph test all on one fixture. That test will get you by if you follow this pool school article: http://www.troublefreepool.com/pool-...ary_pool_guide
    Then if the pool does get out of control, I would dump it and start over.
    38,303
    Ah, missed the size of the pool
    The 6-way HTH from Walmart would get you almost everything ... but again with the size of the pool, not sure how important it is to be testing CH.
    pH, TA, FC, and CYA are still pretty important.
    Or just test for pH and TC and try to track the CYA based on what you add. IF the pool heads downhill ... just start over.
    Jun 2013
    Massachusetts
    8
    It's ok, thank you, I seen one of those test kits, I'll pick one up. Like I said, it's small, but I really don't want to be dumping water every other day, it may be small, but the water bill does add up. I appreciate this thank you. Once our weather gets better, I'll just start all over, I may be better off since there is pollen galore and the weather has been either raining or cool, sunny and windy!
    Maria
