Page 1 of 3 123 LastLast
Results 1 to 20 of 52
Thread: I need help clearing my pool
    Merc Sof's Avatar
    Jun 2013
    Southern Alabama
    47
    I have an in-ground salt water pool approx 19 x 45. 3 - 5.5 deep around 25,000 GAL. The first warm season I loved the pool and it was clear with mild cloudiness that cleared on it's own. This year I noticed there had been many leaves collect in the bottom of the pool which in-turn has caused algae and cloudy issues. I was able to get the pool clear, clearer than I had ever seen it, then I scooped leaves and it clouded up. Not the green-blue color but with a medium to dark blue color and can't see more than a couple of feet into the pool. I have given a good dose of chorine/bleach to shock it and am waiting to clear.
    I just ordered the TF-100 test kit today so hopefully it will be here soon. I need some advice on how to get it clear again. And what it means to have the deeper blue color.
    Thanks in advance,
    US Army Combat Veteran
    27,000 Gal Salt Water Pool
    Vinyl Liner
    Aqua-rite SWG
    Hayward pump and Sand filter
    Polaris pressure side pool cleaner with booster pump
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: I need help clearing my pool
    Welcome to TFP! Step one is out of the way already with having the kit on the way. Not really much you can do until we have a full set of test results. Spend some time reading pool school and the "defeating algae" threads while you wait. We will help you, but there is a foundation of knowledge that has to be built first.
    Merc Sof's Avatar
    Jun 2013
    Southern Alabama
    47
    Thank you
    Vinyl Liner
    Aqua-rite SWG
    Merc Sof's Avatar
    Jun 2013
    Southern Alabama
    47
    These are the test results of this cheesy Aqua Chem Smart Strips app on my Android.
    ALK 60
    PH 6.4
    FREE CL 5
    HRD 0
    CYA 200
    Vinyl Liner
    Aqua-rite SWG
    Smykowski's Avatar
    Sep 2011
    3,065
    If those tests are to be believed (big IF), you're going to have to start with a major water replacement to get CYA down. However, I don't trust strips, and wouls wait for the results from a good test kit.
    Butterfly's Avatar
    South Carolina
    10,045
    ^^what Ski said
    Also, you should confirm the pH test and if really below 7, add borax to raise pH up to the low to mid 7's asap.
    While waiting for the test kit, can you take a sample to a pool store for testing?
    You're done SLAMing when:
    Merc Sof's Avatar
    Jun 2013
    Southern Alabama
    47
    Received the TF-100 kit and these are my results:
    Ph 7.5
    FC 1
    CC 20
    TA over 500
    CH over 1100
    CYA 90
    Vinyl Liner
    Aqua-rite SWG
    Merc Sof's Avatar
    Jun 2013
    Southern Alabama
    47
    New readings:
    PH 8.2
    FC 47
    CC 4
    TA 140
    CH 320
    CYA 90
    Vinyl Liner
    Aqua-rite SWG
    30,432
    Merc sof,
    You are running three simultaneous threads with triplicate entries. No one can possibly help you get your pool cleared when you are posting identical post all over the forum. I have temporarily locked your other threads. Do not start another one. Keep all your posts under this thread.
    Now, to ATTEMPT to help....
    The test results from yesterday and then from today are IMPOSSIBLE to gain any meaning from. Let's try to sort them out one at a time.
    pH - You have posted pH of 6.4 7.5 and 8.2. Are you doing something to adjust pH? If so, you need to tell us what you are doing. Please answer just that question for now.
    EDIT - make that four simultaneous threads. I deleted the last one.
    Merc Sof's Avatar
    Jun 2013
    Southern Alabama
    47
    Sorry about the multiple threads. I will not do that again. I have not tried to adjust the PH. The first two readings are not accurate. The first Was a test strip, the second was my first use of the TF-100 and I probably made errors. The 8.2 reading is consistent.
    Vinyl Liner
    Aqua-rite SWG
    Butterfly's Avatar
    South Carolina
    10,045
    Quote Originally Posted by Merc Sof
    Merc, don't test the pH until the FC is less than 10. It will read a false high. So your 7.5 from yesterday is probably correct.
    The FC is 47, iow, you counted 94 drops?
    Butterfly's Avatar
    South Carolina
    10,045
    Tell us how your water looks and it would be nice if you would post a pic.
    Merc Sof's Avatar
    Jun 2013
    Southern Alabama
    47
    Yes I counted the drops. The water is a turquoise to bluish/green. Cloudy and can't see to the bottom. Uploading pictures now.
    Vinyl Liner
    Aqua-rite SWG
    Merc Sof's Avatar
    Jun 2013
    Southern Alabama
    47
    It is raining so these are the best I can take.
    Vinyl Liner
    Aqua-rite SWG
    Merc Sof's Avatar
    Jun 2013
    Southern Alabama
    47
    Will not allow me to upload because of file size
    Vinyl Liner
    Aqua-rite SWG
    Merc Sof's Avatar
    Jun 2013
    Southern Alabama
    47
    I was able to take another picture.
    Vinyl Liner
    Aqua-rite SWG
    Butterfly's Avatar
    South Carolina
    10,045
    Nice pool
    Are you using bleach/liquid chlorine for the shock process?
    There is no need to raise FC to 47. The shock level range is between 23 and 35 for normal shocking.
    Follow the directions in Pool School and let us know if you have any questions.
    When you have time, please test your fill water for pH, TA & CH. Post those test results back here.
    Have you ever used an algaecide that contained copper?
    Have you had the water tested for metals?
    Just asking the last two ?'s because of your comments about water changing colors.
    Merc Sof's Avatar
    Jun 2013
    Southern Alabama
    47
    I had used the bleach/liquid chlorine to shock the pool and there was no significant changes in the cloudiness/color of the water. By fill water, you mean that I fill the pool with? I have used algaecide but I don't know if it had copper in it or not. I have not had the water tested for metals. How would I go about testing for metals?
    Thanks for the compliment
    Vinyl Liner
    Aqua-rite SWG
    Casey's Avatar
    SW PA
    10,461
    Take it to the pool store and have them test for metals. Algaecides usually contain copper and if you use too much, it builds up.
  20. Back To Top    #20
    Merc Sof's Avatar
    Jun 2013
    Southern Alabama
    47
    Thanks Casey.
    Where in PA are you?
    Vinyl Liner
    Aqua-rite SWG
