Thread: First test this year
    Jul 2011
    Webster,Wi
    59
    I did a test and found my ph at 7.2 and the TA is 100 with the cya at 30. Should I get the cya up first to 80 and then work on the ph or the other way around. It is going to be awhile before we can swim because the weather here in NW Wi. can't even get to 70 and I don't have the heater hooked up yet so I have time to get the levels perfected.
    18'x52" Intex round AGP, 2650 Krystal Clear SWG pump with sand filter and a Hayward H100ID pool heater. TF100 test kit to keep the water sparkly clean.
    Smykowski's Avatar
    Sep 2011
    3,065
    Re: First test this year
    The high TA will make the pH drift upwards. Keeping pH in check after the rise will take care of TA. Basically, I would just monitor them both, but as of now don't worry about proactively changing them.
    Jul 2011
    Webster,Wi
    59
    I will just monitor the ph and TA but will get the cya up.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Quote Originally Posted by MK1985
    Target 70 when you add CYA. If you come up a little short, it's easy to add more, but to lower it you'd need to drain and would lose salt, too.
