Thread: intex ultra frame 18 x 9 x52 setup issue
    May 2013
    Chandler Arizona
    78
    finished setup yesterday. everything went well until the end. the log side started to bow in as the pool was about 1/2 way full ( i read this happens and will straighten out when pool is almost completely full) the long side did completely straighten out just like I read from other owners of the exact pool. Yay My issue happend at the very end. i had been walking around the pool checking and sometime pulling on the legs to make sure they were extended fully as the pool filled. when the pool was full on my last walk around I found two of the pads under two of the legs had moved like to a 20 degree angle < looks like top of this sign now. the pool is still level but am afraid of what may happen during monsoon weather here in arizona. the bottom is sand but covered with heavy duty tarp and gorilla pad. should i just leave it alone and fix it in the winter
    Intex Ultra Frame 18 x 9 x 52 rectangle. 4545 Gallons.
    12 in Krystal Clear™ Sand Filter Pump w/ GFCI.
    Krystal Clear Saltwater System™ w/ GFCI.
    TF-100 Taylor testing.
    K-1000 Taylor testing.
    May 2012
    Omaha, Nebraska
    10
    Re: intex ultra frame 18 x 9 x52 setup issue
    That's what I did with mine. This spring I poured a concrete pad around the perimeter. Kind like a foundation.
    12x24x52 rectangular ultra frame
    8400 gallons
    Sand filter
    Ag vinyl
    May 2013
    Chandler Arizona
    78
    So you left it alone for the season then fixed it in the spring? It didn't continue to bow?
    May 2012
    Omaha, Nebraska
    10
    When the pool was full it didn't bow.
    8400 gallons
    Sand filter
    Ag vinyl
